Data Field: Dozen Run Fields
Dozen Run, Swim, Paddle and Cycle Data Fields
After others are forcing you to pay for these applications, so I decided to make a great data field(s) and then keep them free. I'm a Software engineer, sponsored runner and run coach, I combined my engineering and running knowledge to bring you these streamline applications.
I put thousands of hours of bench and field testing these simple applications. So, consider a small donation.
Small donations (help keep my effort going) paypal.me/fbbbrown
Install Instructions:
This Data field needs to be added to the (specific) app within your watch to view.
This is a data field not an application and needs to be added to a single data screen within an application.
a.) Goto settings,apps,run,data screen,screen 1
b.)Set Layout to 1 Field
c.) Set Field 1 to ConnectIQ Fields, DozenRun
d.) run happy!
INSTALL ISSUES:
-"!" Issue: If you receive a "!", completely uninstall, reboot and then reinstall. The Setting file changed and the automated Garmin install is not replacing the setting file.
-Download Issue: if you have the "App requires an update before install", hard reboot your watch TWICE and install again.
-TIMER Issue: If you update/install and you see the TIMER and don't see the Dozen data field.
--The data field update or install may require a restart of watch.
--Or the data field needs added to the built-in application, again.
These are becoming a Data Field Suite, where all field are similar making it easier to read while in an activity.
The Dozen fields are intended for training, the data field works fine for speed work, track or races, but readability in these conditions maybe tougher.
IMPORTANT: If you have a Question, recommendation or problem.
Please provide as much as possible (for example the following):
1.) Watch type, Watch firmware version and ConnectIQ version.
2. programmed from Garmin Connect (phone type) or Garmin Express
3.) Which data field
4.) description of issue
5.) if its a "!" error include the error log from your watch. Connect your watch to a PC using USB cable. The error log is located x:\GARMIN\APPS\LOGS. copy the listing and paste in the post.
Layout Dozen Run Datafield fenix3
Cad|HR
Pace|Distance
Battery meter
Avg Pace| (bluetooth) Timer
Calories|Time|Elevation
GPS
Layout Dozen Run Datafield FR 230/235/630
Cad|HR
Pace|Distance
Battery meter
Elevation|Time|Calories
GPS
Layout Dozen Run Datafield FR 920XT
Pace|Timer
Battery meter
Avg Pace|HR| (bluetooth) Distance
Cad |Time|Elevation
GPS
Layout Dozen Cycle Datafield
Cad|HR
Speed|Distance
Battery meter
GPS
Layout Dozen Swim data field
Laps | SWOLF
Pace| Distance
Battery meter
Average Pace | (bluetooth) Timer
Calories| TIME | Stroke Type
GPS
Layout Dozen Paddle Datafield
AHR|HR
Speed|Avg SPD
Battery meter
Timer| Distance(bluetooth)
Cad|Time|AVG CAD (stroke distance)
GPS
Description for all fields
--All watch types are support for all data fields. Coded simple to keep bugs at minimum.
-Race Prediction completely configurable for any distance. Distance is entered in meters. Enter 1%-2% longer distance to adjust for normal GPS error and better race prediction.
-Cadence either from watch, footpod or crank cadence. Color coded to provide instant readability
-Heart Rate field is configurable to several methods: calculation (default), manual entered max HR, or individual zones Color coded to provide instant readability
-Pace/Speed is a rolling average to give a smooth reading configurable from 1 second to 120 seconds (Metric or statute by user setting)
-Distance is the total distance for the activity (Metric or statute by user setting)
-Timer is the actual time of the active time. Not Elapsed time.
- Battery meter uses the entire screen for reliability and acts as a divide to help focus one the upper fields.
-Avg Pace\Speed is a Garmin's provided datafield. (Metric or statute by user setting)
-Calories is the activity calories.
-Elevation based on Garmin's values. (Metric or statute by user setting)
-Time of day either in 12hr or 24 hour (based on user setting)
-(Fenix3/920)Auto background color Black or White background based on app settings
-(230/235) Configurable background color Black or White background (user configuration)
-GPS uses same indicator as iPhone for GPS signal. 5=full, 4=usable, 3=poor, 2=unused, 1= last location & 0 = no GPS
-Blue Tooth connectivity is shown as a blue "B"
-Paddle Stroke distance is a calculated by actual speed / cadence. Displayed in Meters/Feet.
#runhappy
  • I noticed that. I think I like this configuration! Thank you!
  • Hi - this is the best datafield so far! Just one tweak would make it perfect for me - it has probably been raised elsewhere, but I've not been able to find it! I would love to be able to change the current pace to lap pace, as this is a metric I use all the time for progression runs, tempo runs etc Any chance of adding this as a configurable option? Thanks!!
  • thebusboy , for the IQ 2.x watches the Lap Pace function already is there and shows a true lap pace. There is no more room for the 1.x watch types
  • Two quick questions. I have a Vivoactive 3 now, coming from using this data field for several months on a Vivoactive HR.
    - Is there a way to NOT color in the whole field for HR and cadence? I have it set for a black background, and the white don't sometimes is hard to see on the colors.
    - the Vivoactive HR would let you change how many data fields were on each screen, so you could have 1 field on screen 1, 3 on screen 2, and 2 on screen 3. The Vivoactive 3 appears to require them all to be the same, so if I use this data field, all screens have to be 1 field. Am I missing how to do this?
  • I can make an update for the color. I have a VA3 and yes that is the case. Only one selection for all screens,. i suggest requesting in the VA3 forums to add that functionality.
  • I have an issue which I hope I can sort out here. In the last months Garmin is trying to solve IOS 11 issues with IQ data, as for the moment you cannot edit settings on the phone. They are aware of it but it takes ages... Furthermore Dozen Cycle gives an error (always did) of trying to change setting in Garmin Connect desktop on a Mac.
    So, is there another way (edit some files) to change the settings?
    Thanks/
  • meste7 , i use an Iphone X with no issues, consider restarting Connect App or even removing it . The activities are stored at garmin and will be restored back into the connect app.
  • fbbbrown , I just did what you suggested and... no, still the same issue. As I said Garmin acknowledged to me that they are aware of it, but not sure when if a solution will be ready... So, any other way to edit those settings? Thanks
  • @meste7, Other than garmin Express or Connect App, No there are no other ways. What do you need changed?
