Data Field: Dozen Run Fields
Dozen Run, Swim, Paddle and Cycle Data Fields
After others are forcing you to pay for these applications, so I decided to make a great data field(s) and then keep them free. I'm a Software engineer, sponsored runner and run coach, I combined my engineering and running knowledge to bring you these streamline applications.
I put thousands of hours of bench and field testing these simple applications. So, consider a small donation.
Small donations (help keep my effort going) paypal.me/fbbbrown
Install Instructions:
This Data field needs to be added to the (specific) app within your watch to view.
This is a data field not an application and needs to be added to a single data screen within an application.
a.) Goto settings,apps,run,data screen,screen 1
b.)Set Layout to 1 Field
c.) Set Field 1 to ConnectIQ Fields, DozenRun
d.) run happy!
INSTALL ISSUES:
-"!" Issue: If you receive a "!", completely uninstall, reboot and then reinstall. The Setting file changed and the automated Garmin install is not replacing the setting file.
-Download Issue: if you have the "App requires an update before install", hard reboot your watch TWICE and install again.
-TIMER Issue: If you update/install and you see the TIMER and don't see the Dozen data field.
--The data field update or install may require a restart of watch.
--Or the data field needs added to the built-in application, again.
These are becoming a Data Field Suite, where all field are similar making it easier to read while in an activity.
The Dozen fields are intended for training, the data field works fine for speed work, track or races, but readability in these conditions maybe tougher.
IMPORTANT: If you have a Question, recommendation or problem.
Please provide as much as possible (for example the following):
1.) Watch type, Watch firmware version and ConnectIQ version.
2. programmed from Garmin Connect (phone type) or Garmin Express
3.) Which data field
4.) description of issue
5.) if its a "!" error include the error log from your watch. Connect your watch to a PC using USB cable. The error log is located x:\GARMIN\APPS\LOGS. copy the listing and paste in the post.
Layout Dozen Run Datafield fenix3
Cad|HR
Pace|Distance
Battery meter
Avg Pace| (bluetooth) Timer
Calories|Time|Elevation
GPS
Layout Dozen Run Datafield FR 230/235/630
Cad|HR
Pace|Distance
Battery meter
Elevation|Time|Calories
GPS
Layout Dozen Run Datafield FR 920XT
Pace|Timer
Battery meter
Avg Pace|HR| (bluetooth) Distance
Cad |Time|Elevation
GPS
Layout Dozen Cycle Datafield
Cad|HR
Speed|Distance
Battery meter
GPS
Layout Dozen Swim data field
Laps | SWOLF
Pace| Distance
Battery meter
Average Pace | (bluetooth) Timer
Calories| TIME | Stroke Type
GPS
Layout Dozen Paddle Datafield
AHR|HR
Speed|Avg SPD
Battery meter
Timer| Distance(bluetooth)
Cad|Time|AVG CAD (stroke distance)
GPS
Description for all fields
--All watch types are support for all data fields. Coded simple to keep bugs at minimum.
-Race Prediction completely configurable for any distance. Distance is entered in meters. Enter 1%-2% longer distance to adjust for normal GPS error and better race prediction.
-Cadence either from watch, footpod or crank cadence. Color coded to provide instant readability
-Heart Rate field is configurable to several methods: calculation (default), manual entered max HR, or individual zones Color coded to provide instant readability
-Pace/Speed is a rolling average to give a smooth reading configurable from 1 second to 120 seconds (Metric or statute by user setting)
-Distance is the total distance for the activity (Metric or statute by user setting)
-Timer is the actual time of the active time. Not Elapsed time.
- Battery meter uses the entire screen for reliability and acts as a divide to help focus one the upper fields.
-Avg Pace\Speed is a Garmin's provided datafield. (Metric or statute by user setting)
-Calories is the activity calories.
-Elevation based on Garmin's values. (Metric or statute by user setting)
-Time of day either in 12hr or 24 hour (based on user setting)
-(Fenix3/920)Auto background color Black or White background based on app settings
-(230/235) Configurable background color Black or White background (user configuration)
-GPS uses same indicator as iPhone for GPS signal. 5=full, 4=usable, 3=poor, 2=unused, 1= last location & 0 = no GPS
-Blue Tooth connectivity is shown as a blue "B"
-Paddle Stroke distance is a calculated by actual speed / cadence. Displayed in Meters/Feet.
#runhappy
  • I just had a run on my FR235 with latest FW update and Dozen was quite "wavy" in giving last 12 seconds pace, so I uninstalled and tried to re-install.
    My pace per km was relativly constant (around 4'46" following my table), while Dozen often gave me > 5'/km pace.
    https://connect.garmin.com/modern/activity/1129737511
    Suggestions?
    Thanks
    It's likely nothing in code, since I use the same averaging code in all of my Datafields. However im interested. send me your .fit file.
    Try lowering the period. I'm planing to change my smoothing from a time period to a distance(s). My new algorithm uses much less memory and I've been using a beta for months now.
  • Any chance for Epix version?
    Done, check the app store.
    Former Member over 9 years ago
    Is there a reason why dozen run shows calories on the 235 but not on the f3hr?
    Doing weightl oss so calorie info would be nice.
  • It's likely nothing in code, since I use the same averaging code in all of my Datafields. However im interested. send me your .fit file.
    OK, can you please give me an eMail where to send them?
    Thanks
    - enrico
    PS
    I can try your beta if you'd like.
    Could this not render the footpod useless with this data field?
    Footpod gives instant and accurate pace compared to GPS.
    But if you calculate pace from distance then the pace would be calculated from GPS data unless you're running indoors and using the footpod for distance in addition to pace.
  • Could this not render the footpod useless with this data field?
    Well put, and i agree with that. thats why i haven't released not sure of the down side.
  • OK, can you please give me an eMail where to send them?
    Thanks
    - enrico
    PS
    contact me through apps.garmin.com, then I will reply. I shouldn't post my email here.
  • Is there a reason why dozen run shows calories on the 235 but not on the f3hr?
    it displays as "999c" & it should be on the lower right with RUN version, if your using the CYCLE version Calories and Total Ascent are an options on the lower right. these can be changed using Connect Phone App or Garmin Express. there instructions in these forums on how to change configurable items.
  • tempe support
    thank you very much for this great datafield! Would you please consider to add tempe temperature as a choice for the lower right?
  • contact me through apps.garmin.com, then I will reply. I shouldn't post my email here.
    On apps.garmin.com when i push the button "contact the developer" nothing happens...
    I tried with Chrome and MSIE: same result.
    Suggestions?
    _________
    PS Thanks Brian for GREAT SUPPORT!!!
