Data Field: Dozen Run Fields
Dozen Run, Swim, Paddle and Cycle Data Fields
After others are forcing you to pay for these applications, so I decided to make a great data field(s) and then keep them free. I'm a Software engineer, sponsored runner and run coach, I combined my engineering and running knowledge to bring you these streamline applications.
I put thousands of hours of bench and field testing these simple applications. So, consider a small donation.
Small donations (help keep my effort going) paypal.me/fbbbrown
Install Instructions:
This Data field needs to be added to the (specific) app within your watch to view.
This is a data field not an application and needs to be added to a single data screen within an application.
a.) Goto settings,apps,run,data screen,screen 1
b.)Set Layout to 1 Field
c.) Set Field 1 to ConnectIQ Fields, DozenRun
d.) run happy!
INSTALL ISSUES:
-"!" Issue: If you receive a "!", completely uninstall, reboot and then reinstall. The Setting file changed and the automated Garmin install is not replacing the setting file.
-Download Issue: if you have the "App requires an update before install", hard reboot your watch TWICE and install again.
-TIMER Issue: If you update/install and you see the TIMER and don't see the Dozen data field.
--The data field update or install may require a restart of watch.
--Or the data field needs added to the built-in application, again.
These are becoming a Data Field Suite, where all field are similar making it easier to read while in an activity.
The Dozen fields are intended for training, the data field works fine for speed work, track or races, but readability in these conditions maybe tougher.
IMPORTANT: If you have a Question, recommendation or problem.
Please provide as much as possible (for example the following):
1.) Watch type, Watch firmware version and ConnectIQ version.
2. programmed from Garmin Connect (phone type) or Garmin Express
3.) Which data field
4.) description of issue
5.) if its a "!" error include the error log from your watch. Connect your watch to a PC using USB cable. The error log is located x:\GARMIN\APPS\LOGS. copy the listing and paste in the post.
Layout Dozen Run Datafield fenix3
Cad|HR
Pace|Distance
Battery meter
Avg Pace| (bluetooth) Timer
Calories|Time|Elevation
GPS
Layout Dozen Run Datafield FR 230/235/630
Cad|HR
Pace|Distance
Battery meter
Elevation|Time|Calories
GPS
Layout Dozen Run Datafield FR 920XT
Pace|Timer
Battery meter
Avg Pace|HR| (bluetooth) Distance
Cad |Time|Elevation
GPS
Layout Dozen Cycle Datafield
Cad|HR
Speed|Distance
Battery meter
GPS
Layout Dozen Swim data field
Laps | SWOLF
Pace| Distance
Battery meter
Average Pace | (bluetooth) Timer
Calories| TIME | Stroke Type
GPS
Layout Dozen Paddle Datafield
AHR|HR
Speed|Avg SPD
Battery meter
Timer| Distance(bluetooth)
Cad|Time|AVG CAD (stroke distance)
GPS
Description for all fields
--All watch types are support for all data fields. Coded simple to keep bugs at minimum.
-Race Prediction completely configurable for any distance. Distance is entered in meters. Enter 1%-2% longer distance to adjust for normal GPS error and better race prediction.
-Cadence either from watch, footpod or crank cadence. Color coded to provide instant readability
-Heart Rate field is configurable to several methods: calculation (default), manual entered max HR, or individual zones Color coded to provide instant readability
-Pace/Speed is a rolling average to give a smooth reading configurable from 1 second to 120 seconds (Metric or statute by user setting)
-Distance is the total distance for the activity (Metric or statute by user setting)
-Timer is the actual time of the active time. Not Elapsed time.
- Battery meter uses the entire screen for reliability and acts as a divide to help focus one the upper fields.
-Avg Pace\Speed is a Garmin's provided datafield. (Metric or statute by user setting)
-Calories is the activity calories.
-Elevation based on Garmin's values. (Metric or statute by user setting)
-Time of day either in 12hr or 24 hour (based on user setting)
-(Fenix3/920)Auto background color Black or White background based on app settings
-(230/235) Configurable background color Black or White background (user configuration)
-GPS uses same indicator as iPhone for GPS signal. 5=full, 4=usable, 3=poor, 2=unused, 1= last location & 0 = no GPS
-Blue Tooth connectivity is shown as a blue "B"
-Paddle Stroke distance is a calculated by actual speed / cadence. Displayed in Meters/Feet.
#runhappy
    calories
    I love this widget.
    Anyway you can configure between calories and training effect?
  • I love this widget.
    Cardingtr, thanks. This is one metric I really want too, but the watch crashes when training effect is used. TE works on the simulator but not in the fenix firmware. It's a known Garmin IQ SDK bug.
  • Pace field configurable?
    Love this app and all the other data fields you have written. You have given a lot of thought and time - really appreciate it!
    Any way I can change the current pace field to lap pace? Do you post the source code anywhere or can share samples to get started with Connect IQ programming?
    Thanks!
  • [ R ] request Avg PAce
    Hello developer,
    I think your App is the best I ever tried on my FR235.
    I used to run looking, even, at the Average Pace of my run; now I'm trying to adapt my pace to the estimated arrival time, but it looks difficult to me.
    So... here's the REQUEST: is it possible to enable the possibility to have the "ETA" that changes every 5 seconds with the Avg Pace?
    Thanks for listening, anyway
    - enrico
  • Love this app and all the other data fields you have written. You have given a lot of thought and time - really appreciate it!
    Thanks!
    Check out my lap by position datafield it my do exactly what you want.
  • Hello developer,
    - enrico
    Thanks!
    In latest release I added the ability to predict finish times. That may be what your looking for. In connect or Garmin express configure the prediction distance to match your run and the average pace field will now show your predicted finish time.
    Hope that helps!
  • Thanks!
    Hope that helps!
    Hello,
    Well... no, it doesn't: I still am using your recent prediction for Estimated Arrival Time (ETA), and it works fine.
    What I'd love to see is this field showing - alternating every 5 seconds - the ETA and the Average Pace.
    Can you?
    Thanks
    PS
    Yesterday I had an Half-Marathon (Stramilano) and I used this field; I kept 4':39"/km as average run, but I very often had different paces indications (> 5'/km) during the run.
    Is this a problem of the App/Garmin, or what else? I used 12 seconds pace, as suggested.
    This is the track-run:
    https://connect.garmin.com/modern/activity/1092189388
  • Note: I found the fenix3 dozen run v1.7.1 field average pace is out of position. I will fix tomorrow. Sorry for the hard to read pace field 😩
  • THIS FIELD IS THE BEST EVER SEEN!
    Fantastico: bravissimo.
  • Fenix 3 HR Version
    Howdy - I have been using your data field on my Fenix 3 and was wondering if you make it compatible with the Fenix 2 HR?
    Many thanks.
    MD
