Nightscout Widget Help
This is a thread so that anyone can feedback about the Nightscout Widget.
  • still having issues
    Hi guys
    Still having issues trying to get this to work.
    My nightscout website is working. I can get my readings to the cgm-watch app from the other developer.
    There is only one field available to input my site. I have tried https://mycgm.azurewebsites.net, also tried mycgm but no further forward just saying no internet connection.
    Any help appreciated.
    Thanks
    Former Member over 8 years ago
    Change Time Display
    This widget is awesome. I am really glad I got this all up and running. Any chance you can allow the user to specify a setting to change the time display to either select 12 hr or 24 hour format?
    Thanks!
  • Source Code Using Herokuapp
    Hello, I am using Heroku to host my nightscout app. Hence I am unable to configure my site on your app. I have been building a widget of my own and wondered if the source code for your App is available as it looks like you have already implemented everything I would want to! thanks.
    Iain
    Time format
    Thanks!
    Thanks for the feedback, I'll try to include this in the next release. R.
    How to Heroku
    Iain
    Hi Iain, the widget should work with Heroku, but you have to set the domain on the watch itself. To do this get the widget loaded and go into the menu. This is either a menu button or holding the up key. You should find a menu item called Host Domain in the Settings menu. You should be able to set the domain to Heroku rather than Azure. If it doesn't work, send me a message via contact developer in the app store with the Heroku but of your URL.
    To navigate the menus you have to swipe across and tap on touch screen watches, or up and down arrows and the runner button on other watches. You might need to explore it a bit.
    This function predates settings on the phone.
    Happy to collaborate on the development if you want, it might be better than lots of different apps. R.
