WatchFace: LCARS III
Digital watch face for Star Trek fans. It is compatible with SDK 1.1.4 but some functions need SDK 1.2.1
Colors can be configured via Garmin Connect Mobile or Garmin Express
Compatible Devices: ForeAthlete 235J, Forerunner® 230, Forerunner® 235, Forerunner® 630
    Former Member over 9 years ago
    The inactivity monitor activate a little "alarm" to tell you that you need to move every hour. The bars are fulfilled when you moved enough, after an hour of inactivity, the first bar is turn off, and you have some minutes (i don't know how many) to move enough until all the bars turn off. Once you move enough (walk around 2 minutes), all the bars are turned on again.
    Thank you, that explains it! Love this watchface. Thanks for creating it.
    How the move bar comes and goes...
    The "move bar" had 5 levels and are often shown as 1 big segment and 4 smaller ones.
    The big one comes on after an hour where you haven't walked enough (you could have walked, but not enough). The next 4 are for each additional 15 minutes. So you get all 5 after 2 hrs.
    To clear the move bar, it requires steps, without stopping. If you only hit the 1hr, it takes about 100 steps, and then 25 more for each additional level, so with all 5 levels, it takes about 200 steps.
    Thanks, that helps a lot!
