I am curious to see what people are doing with watch faces. Here is what I am using right now for a watch face:
Simulator:
Actual:
Also, apologies to the mods if this post should not be here. Delete if needed :)
It is not a problem. I'll do it tomorrow - in my country is late in the evening and I am going to sleep..
fenix 3 supports only 16 colors, so you can not create the same graphics as the android watches have
Got mine, i've been tweeking here and there for the last few days.
Steps count above on the right, becomes yellow when 80% of the goal is reached, and green when target is reached (and starts to omit the target from that point). Also shows when Sleep mode is on.
Battery level becomes red when below 30%
Loving to play with the SDK. Really looking forward for the future resources.
Rendering the red line, blue blob, the weather icons, the time, temperature, and date would not be a problem. It might not look as refined (the Garmin devices are relatively low resolution, and have support for a rather limited number of colors), but displaying the data like this would be possible. Getting the data onto the device on the other hand, that is an issue. Watch faces don't have access to communications facilities, so there is currently no way to display actual weather data.
