DataFields: RunnersField
# RunnersField / BikersField
These are free Data Fields for the Fenix 3 that show multiple values on a single field.
RunnersField and BikersField are open source and their code resides at github: https://github.com/kopa/RunnersField and https://github.com/kopa/BikersField
If anyone wants to contribute or report bugs please head over to RunnersField@github or BikersField@github.
The code is licensed with the MIT License. So anyone can do what he/she wants with the code.
Release versions are published in the Garmin App Store
## Features RunnersField
* TIME: 12/24h mode based on system settings.
* PACE: pace in km/min or mi/min based on system settings (as average of the last 10 values).
* AVG PACE: average pace over the whole activity.
* DISTANCE: elapsed distance in km or miles based on system settings.
* DURATION: duration of the activity in [hh:]mm:ss
* GPS: green/blue bars for poor/acceptable/good signal, gray if no signal.
* battery: visualization of battery percentage as indicator bar.
If battery value is lower than 30 the indicator bar gets orange. If value is lower than 10% the exact value will be shown and the indicator bar turns red.
* unit system in use: "(km)" will be shown when metric system is set in the settings, "(mi)" if statute (imperial) units are configured.
* use bright or dark color scheme based on the background color setting of the app (Settings/Apps/Run/Background Color).
needs at least a firmware with SDK 1.2 compatibility (otherwise bright scheme is always used).
## Features BikersField
* SPEED: speed in km/h or mi/h based on system settings (as average of the last 10 values)
* AVG SPEED: average speed over the whole activity.
## Install Instructions
A Data Field needs to be set up within the settings for a given activity (like Run)
* Long Press UP
* Settings
* Apps
* Run
* Data Screens
* Screen N
* Layout
* Select single field
* Field 1
* Select ConnectIQ Fields
* Select RunnersField
* Long Press Down to go back to watch face
## Usage
Start Run activity.
Hopefully you see the RunnersField datafield.
## Changelog 1.2.3
* fix app name
## Changelog 1.2.2
* fix colorscheme background detection
## Changelog 1.2.1
* change battery critical color
## Changelog 1.2.0
* Use bright/dark color scheme based on app background color settings
* Add german language file
## Changelog 1.1.1
* Further improve memory footprint
## Changelog 1.1.0
* Redesign
* Improve memory footprint
## Changelog 1.0.2
* Fix when black background is configured in device settings.
* Add battery percentage if < 10% left and make visualization red.
* Fix irrelevant slow pace values
* Change string TIMER to DURATION
* Change string metric to km and statute to miles
## Changelog 1.0.1
* Time mode is now dependent on device settings (12/24 hours mode)
* Distance and pace will be presented dependent on device settings (metric [km, km/min] or statute [miles, miles/min]), "metric" or "statute" will be shown below battery/gps
* HR is now dark red to visually decipher the different values faster
## Changelog 1.0.0
* Time of day
* Current Pace (average over 10 seconds)
* Average Pace
* Heart Rate
* Distance
* Timer
* Battery Status
* GPS Status (green = gps lock, red = no gps lock)
    Former Member over 10 years ago
    Hello, The desktop remain Black and rest is White. Sorry my English.
    I didn't test with black background. Background color detection is coming in the next sdk (1.2.0) didn't test with black background.
    I will fix this in the next release!
    Thanks for reporting this bug! version, that is beta right now, so the app will be able to react accordingly.
    I will fix this as soon as we can use the new sdk with the release firmware.
    Nice apps, can the background color be changed to Black color ? Thanks.
    dark background
    In the next SDK version there will be a function that can detect the settings for the background color. As soon as the Firmware/SDK version is released I will try to use this and provide a dark UI in case the background color is set to black.
    Thanks Kpaumann for your reply. This is a very nice widget, I love it. Looking forward for the update.
    Previous design
    Edit: After I have used it several times I take my previous statement back. The new look is great and easy to read. Thanks for this data field. It is my favourite!
    Great Data Field though I prefer the previous design. Can you please add the vertical lines to separate the fields?
    Crashes w. V6.0.11b
    Crashed on my Fenix 3 running 6.0.11b.
    I have not tested it with the beta firmware on the watch itself. On the Simulator it is running fine. Will look into it.
    I uploaded a new version 1.1.1 that further reduces memory consumption. Hopefully it runs with 6.0.11 beta firmware. Could you try it? That would be really great!
    Thanks.
    With SDK 1.2.0 there will be app settings. I could implement an option to toggle the separators from those app settings.
    Thanks for your report!
