Which weight settings does Run Power utilize for calculations? Garmin or Stryd
Does it'll create a conflict if two different weight settings are used?
Thanks
Thanks
while the run power algorithm isn't published, I'd guestimate if body weight is used in run power at all it'd be for sure whatever you have inputted in your garmin settings.
