WATCH FACE: SHN Tactical
Hye!
Let me introduce you my Garmin Watch face: SHN Tactical
Avaliable here: SHN Tactical.
Tactical Watchface with (from top to bottom) :
- Phone statut : Connected / Alarm / Dot not Disturbed (if avaliable)
- Separator line
- Dual time with hour/min offset from your current time and time zone letter (DST on/off) or Daycounts or Position
- Time in military format with always on sec (if 1hz avaliable) and second on ring
- date with 3 different format : EEE dd MMM [w/y] / EEE MMM dd [w/y] / NATO Format with dst indication
- Astrological information with time left to (sunrise/sunset), timeline , sunrise and sunset time, moon phase or bigger fitness data
- Small field with either Position (MGRS DEG DEM from the last position known)
or Fit data gauges from top to bottom and left to right steps, floors (if avaliable), Calories (goal can be set), weekly active minute, distance, HR
or Small astro information.
- Battery information and notifications count
colors can be set.
This is my first Watch Face so if something wrong, please let me know.
Astrological info are calculated from your GPS position, if it doesn't work start an activity and wait for GPS location.
    Former Member over 5 years ago in reply to Shent-Aurkhan (SHN)
    Ah, somehow I didn't realize about the sun event ahah!
    Thank you for considering an option for removing HR from fitness data for both "bigger" and "small" data fields.
    It's just for battery saving purposes, for those of us who want to squeeze a few extra hours out of our watches :)
    Thanks for the awsome watchface!
  • Since today's update I've lost my Pro features!
  • What is the small "14 H" I notice suddenly at the bottom of the watch face?
  • hi, this the the estimated battery time left
    Hello, am getting blank screen on vivoactive 4; 3.40 firmware.
    Watchface is updated to latest version
    Former Member over 5 years ago in reply to Former Member
    Hi, this was firmware related.
    Watchface works fine after installing latest firmware
    Did find a bug though :D clicking "hide HR" does NOT remove Heart Rate from Small Data field (when small data field is set to fitness data+steps)
  • Hello,
    Got a couple questions and a recommendation.
    1. When using weather. What is the upper data information. Mine is showing 12-15 and then 3 different weather fields. And below those 3 fields, the word MARYLAND.
    What is the 12-15? what are the 3 fields, next 3 hours? Next 3 days?
    And what is MARYLAND? I'm in Dublin Ireland, for reference and my dual time zone is NYC. (which coincides with MARYLAND, but still).
    Is there a way to disable this top-weather information and keep only the left data?
    2. At the very bottom in the center I see a 40. Just 40. What is this?
    Given how dense the information is and how fast you keep changing the features / adding more. I would politely ask/recommend you keep a tight documentation on what each field and information on each field means.
    For instance, deciphering the weather info was a bit of a challange.
  • 1. 12-15 means from 12h to 15h, so understand for the next one 15h to 18h and 18 to 21 (everything is explained in the description)
    Maryland stand for the city open weather map get the weather information,
    so either you haven't update your GPS since you've been in NYC, or you put the custom lat long in the settings "on" and put the coordinate of NYC.
    for the moment, no option to disable top info (but i can add the option)
    2. in the bottom it is 4 D, which stands for 4 days left (battery estimated time)
    I'm working on a "how to use".
    have a great day
