Hello...I installed the app on my Vivoactive HR and noticed that it acquires GPS (or says so), yet the three words never change. Any ideas / solutions?
Thank you!
What3Words requires an internet connection.
That is, you would need to have a phone.
Inputting text into a watch is going to suck anyway.
Use the phone.
Using “plus codes” would be a much better idea.
It’s much fewer characters to input and doesn’t require an internet connection. It also doesn’t require proprietary data owned by one company.
I get your point but if the person I know is using what3words then that is what I have to work with and I did not buy a watch with navigation to then walk around using my mobile phone to navigate with. I've not heard of plus codes before though so that is interesting.
The What3Words either needs internet access to encode/decode the words OR the app/widget would need the What3Words "database", which would need to be included in the app/widget code. This would likely make the app too big. You'd likely need to pay for a license to use the "database".
Who is using it? It doesn't seem common at all.
It seems pretty silly to use a proprietary method for indicating a location.
I do have a workaround which is more cumbersome than it should be but here it is, in case anybody else wants this feature or can improve upon my mad method (Android)
Yes, use pluscodes instead.
One issue with pluscodes is that the long version is not commonly provided.
What3Words is a "cute" idea that has lots of problems.
The basic problem with it is involving privately-owned proprietary data for passing locations.
