Watchface: Watch Me (Configurable color schemes)
Displays a color configurable digital clock in a large and attractive font.
Convenient and enjoyable experience with improved readability.
Blue was designed with the blue/black 920XT in mind and
Red was designed with the red/white 920XT in mind, but both look great on any other watches!
******** [ FEATURES ] ********
- 12 / 24 hour format
- Seconds in high power mode
- Date
- Battery strength
- Bluetooth indicator when connected to phone
- Move indicator
- Steps and goal
- Sleep mode indicator (Zzz)
- Ability to change color
- Shows paintbrush with next color when process is initiated
******** [ Configurable options ] ********
Choose from 3 different color schemes:
- Blue with orange seconds*
- Green with purple seconds*
- Red with light blue seconds*
(*seconds only displayed in high power mode)
******** [ Configuration Instructions ] ********
First time the watch face is loaded, it will display with the Blue color scheme
To change the color scheme, do the following:
1) Toggle from the watch face to a widget by pressing the up button, and immediately back to the watch face by pressing the down button (this initiates the color scheme changing process and shows a paintbrush with the color that comes next) ##
2) Repeat step 1 immediately to change from Blue to Green
3) Repeat step 1 immediately after step 2 to change from Green to Red
4) Repeat step 1 immediately after step 3 to change from Red to Blue
Once you've reached the desired color, leave the watch face until the paintbrush disappears. The color changing process has now terminated.
##For the vivoactive, toggle by swiping left and right.
e.g. To change to Red, you have to repeat step 1 three (3) times in quick succession. A delay of a few seconds between any key presses will terminate the color changing process, and you will have to start over again (if you haven't reached the desired color).
******** [ Support ] ********
Please support me by tagging your instagram photos or tweets of this watchface with @hermoter and #watchme
Also good reviews and ratings are most welcome!
Please do not leave support issues in the reviews. There is no way I can communicate with you there.
Rather contact me on Twitter: @hermoter
or
email: [email][email protected][/email]
  • On the vivoactive, instead of pressing buttons like the 920xt, swipe left and right to toggle between watchface and widgets.
    It's been confirmed to work here
  • Latest version (2.1.0) is available:
    I fixed an issue where the color changing got stuck after it has been changed to blue (top end of color cycle)
    Also improved the color changing experience.
    Once the process is initiated by the first toggle, a paintbrush appears showing the next color that you can change to.
    Paintbrush disappears after a timeout of inactivity with regards to toggling between the watch face and widgets. This indicates that the watch is no longer in color changing mode.
    Also the time out has been increased so that it is no longer necessary to frantically toggle between screens!
  • Version 3.0.0 is fully compatible with CIQ 1.2.1 and Application / User settings.
    You can configure colors for most of the components on the screen.
    Please ensure that you have the latest version of Garmin Express (4.1.11.0) running.
    There was a bug in earlier versions that caused the wrong settings to be save to the watch, causing colors to become black and thus appear as if they are missing on a black background.
