WatchFace: Edgy Black
Hi,
My first watch face is now public available in Connect Store: ">Edgy Black">Link to Edgy Black
I got inspired from the really nice face "Perimeter" (https://goo.gl/07TJM6) However, I felt the need for quick access to steps and battery information.
Features of the Edgy Black face:
V1.0.0
Low power mode:
- Clean face; Hour and minute hands, plus digital clock.
- 12/24-hour support.
High power mode:
- Daily distance (metric/statute).
- Daily steps and percentage of daily goal.
- Seconds.
- Today's date.
- Battery level.
  • Like this watch face. Unfortunately, it does not properly run on the D2 Bravo. I tried to rotate my wrist this way and that until it hurt. I could never get the display in the high power mode.
    Hmmm... As always when writing code: "It can not be my code that is fault!" ;)
    However, I really don't think your issue is related to this watch face. Have you tested other faces with special behavior in HighPowerMode? It's not a lot you can do in the app, just hooking in some code in pre-defined functions that are called when the watch have reached HighPowerMode.
  • NEW! Change color theme using gesture!
    Version V3.0.0 just released! And with that the face changed name to Edgy Multi Color.
    The routine for changing theme has been tweaked:
    Press Up button to exit watch app, then quickly press Down button to enter watch app again. Now you are in Theme Change Mode. Use "look at watch"-gesture (enter High Power Mode) to switch theme. Continue with the gesture until you reach your wanted theme.
    Change history:
    V3.0.0 2015-09-02
    + Renamed Watch Face!!!!
    + New color theme switching routine!!
    + Now features 12 different color themes.
    + Better contrasting colors.
  • Foreign language...
    It has happened again... Sorry, I don't read chinese :(
    Got this review: "颜色没有以前好看。"
    Google translates to: "Color does not look good before."
    What? Which color? Before what?
    Isn't easy to fix a problem that you can't understand.
    Someone who can do a better translation?
  • PAUL iesord
    It happens when you get multiple text in 2 seconds.
    The new theme changing procedure hopefully will eliminate your problem! :)
    Let me know if not.
  • New thread started!
    Since this face has evolved a bit and even changed name, I started a new thread for these discussions: https://forums.garmin.com/showthread.php?321053-WatchFace-Edgy-Multi-Color
