Application: Sailing
This thread is for any comments or questions regarding my Sailing application. Feel free to post suggestions for new features or bugs. Thanks for using.
Changelog:
#version 0.7
- added a startline screen that displays a countdown, distance and course to startline, ETA (see description)
- added support for D2 Bravo
- Layout updates for Velocity view
- 4 minutes countdown
# version 0.6a
- changed detail layout in velocity view
# version 0.6
- added support for Vivoactive
- added support for Forerunner 920 XT (experimental, Feedback needed via forum)
- Bearing calculation is adjusted (will be calculated every 0.01 NM)
- adjusted interface for the velocity view (former history view)
- Session recording starts after countdown finishes
- added countdown submenu
# version 0.5
- finalized Epix layout (with compass and MOB heading)
- stable MOB results
- race coutdown
- added calculated bearing value
- added Average and 10 second average speed
- improved compass display (the old one was to inconvenient)
- added an activity menu, from which activities can be saved, resumed and discarded
--- press start first time -> activity starts
--- press start second time -> activity menu is shown
# Version 0.4
- added vibration on anchor alert
- additional fixes on MOB (still instable, hope this will work better soon)
# Version 0.3
- fixed some MOB issues
# Version 0.2:
- added support for epix watch
    Rebooting
    Hi,
    I took the Sailing on a test run today om my sailing boat, and it really looks great - does everything I could wish for!
    But, it keeps rebooting my watch. Even without touching anything, when recording it suddenly reboots.
    I am using Fenix 3, v4.00, Swedish and metric (not sure whether these settings might affect). I had to install three times after first two installs I just got an IQ! symbol, but after third install I all looked swell for a few seconds.
    As said, looks like a wonderful app and I really would like to get it working
    Thanks
    Mattias
    Hi,
    Thanks
    Mattias
    Hi Matthias, sorry for the inconvenience. Could youcreate a logfile like it is described in this post and send it to me via private message?
    Another nice feature that we've made added is CIQ logging, which can help you with debugging on the device. Here's how you use it:
    Create /GARMIN/APPS/LOGS on the device
    Inside the LOGS directory make a CIQ_LOG.txt file
    This will log out console messages to the CIQ_LOG.txt file. You can also create a separate log file for each app, where any Sys.println statements called within the app will be written. For example, if your app is called MYAPP.PRG, just create a MYAPP.TXT in /GARMIN/APPS/LOGS
    The app is currently on a point, where memory (RAM) gets short. I think, this might be a reason. But let me take a look at the logs.
    It's updated ;)
    Big Big thanks.
    I think it well be great idea to change a color of numbers - fastest - green lower red
    Big Big thanks.
    Do you mean for the AVG/AVG10 values?
    Yes. This screen is most important ( for my opinion )
    maybe this is a general question - is there a way to not have this activity add to your steps/activity count? I had a killer fitness day when I ran the family 40 miles each way on the bay on Tuesday - burned thousands of calories !!!!!
    oh yeah - one more thing - time of day somewhere would be a useful addition. Or can I exit it to check the time on my watch without stopping the recording of the track?
    thanks again.
    thanks again.
    Hi Duncan, as far as I know this is not possible. Your watch should still count only steps, that you really make. But I get what you mean. The calories are counted like it would be a running activity or something similar. I will take a look into this. The time of the day is allready displayed on the first view after you start the application. It is at the bottom of the view. That the recording is stopping after switching to the watch (pressing down long on the fenix for example) is another thing I'm investigating.
  • maybe this is a general question - is there a way to not have this activity add to your steps/activity count? I had a killer fitness day when I ran the family 40 miles each way on the bay on Tuesday - burned thousands of calories !!!!!
    thanks again.
    Your daily steps and calories will reflect those you do doing a recorded activity. There is no way to prevent this.
    And based on your device, there is a way to get to the default watchface while in an activity. On the vivoactive for example, you press the screen for a few seconds. Once you are at the watchface, you can move to the ativity tracking widget and see your daily steps/calories, or get to the "music control" widget, without stopping your activity. On the va, it will time out and go back to your activity screens, or the back button will take you there right away.
    At the current state this crashes my app. I'm not sure what to do about this behavior
    What you really need for the calories is just he hrm.
    the problem is with the data fields.
    By now with all the requests pouring in, I think different versions of the sailing app could be made.
