Data Field : Single Field (Legacy : Single Run Field)
*** LATEST VERSION : Single Field ***
Link: https://apps.garmin.com/en-US/apps/1d406424-eec1-4155-85f6-24de6c9611e4
Permission Requirements: User Profile (this is needed to get the HR zones), FIT Recording (used to record snacks earned)
Description: Review app store page for most recent and updated information about the field.
*** OLDER VERSIONS ***
NOTE: Legacy versions support devices which are still currently working and links are found here.
Single Field : https://apps.garmin.com/apps/640d46dd-12db-44d2-acfa-cb7eb9e840b7 (Legacy)
Single Run Field : https://apps.garmin.com/apps/a520cc32-75b2-4b19-a97d-1079b931dc3d (Legacy)
Please use this thread to discuss the single data fields. Links to other support resources for these data fields are listed here:
  • Thanks for the feedback. But I don't get your explanation fully. So how do I have the bottom field to show "Cadence | Distance"? I don't see any other options.
    What about the text sizes issue?
    Thanks.
    The screen can be configured to have a couple different layouts (3 field, 2 field, and 1 field). Your app needs to be configured to use the 1 field layout. Once that part is configured you then select "Single Field" as the field to use in that layout. I don't have the Vivoactive HR but my testers have indicated it is working properly so the best I can suggest is go into the data screen configuration and look for the adjustment for number of fields and set that to 1 field.
    Former Member over 9 years ago
    Thanks
    Thanks. I finally understood what your trying to explain. Your app is basically just showing 1 field (the illusion is us thinking it looks like 3 fields!) Now that I switched to 1 field layout & selected your app - the displays are perfect now! Thanks again.
  • Hello all, can someone assist me to fix this app screen as the unique screen on Forerunner 235? I can only put it as the secondary screen, and everytime at work out, this keeps swichting from the primary screen ( that I can define in some fields ) and the secondary screen with the app.. I want to keep only one screen enabled, the screen with single run field. tks a lot
    Once installed on the FR235 for either Single Run Field or Single Field, from the watch face do the following:
    1. Click the top right button once to enter activity selection
    2. Use the up arrow to scroll through the activities till you get to the one you want to customize (probably run or bike), only scroll, don't enter the activity
    3. Select Menu > Activity Settings > Data Screens.
    4​. Select a screen.
    Some screens can only be turned on or off.
    &#8203;5&#8203;. If necessary, edit the number of data fields. <== should be one data field
    6&#8203;. Select a data field to change it. <== should be the Single Field
    problem with HR
    HR is not showing in the single run field anymore, it is showing in the garmin datafields
    I cannot install the app with the HR zones, due to a version error. The IQ Store gives me a notification about installing a newer software version.
    Fenix 3 HR
    Software: 3.6
    The old version can be installed without problems.
  • HR is not showing in the single run field anymore, it is showing in the garmin datafields
    I use the field daily and am not seeing this issue. Can you provide some more information about the watch and firmware version?
    Former Member over 8 years ago
    single run setup fenix 3
    hi . i would like to use this app but it doesnt work on my fenix 3. I have just updated it to 7.60. I added this app to my watch and synchronized using garmin express. Unfortunatly i dont see this app on my fenix. I got no problems with others applicatios but i dont like them. Single run got all i need. Please help me .
    Fenix 3 HR Sapphire - I don't see where on the watch this is enabled
    Hello there
    I have only just started using my Garmin Fenix 3 HR and I wanted this screen as it seems perfect for my needs. I installed it via Garmin connect and it is in the list on the Garmin Connect app on my PC but I have no idea how to enable the data field on my watch. I did see above some instructions but I do not see Single Field available as an option listed under the fields selctions.
    I would appreciate any help on this
    Thank you in advance
    Kris
  • Hello there
    Kris
    After the data field has been installed, it can be configured following these steps. Configure layout to be one field and select Single Field as the choice for that field.
    1. Hold UP.
    2. Select Settings > Apps.
    3. Select the activity to customize. (Choose "Run" for example)
    4. Select Data Screens.
    5. Select a data screen to customize.
    6. Select an option:
    - Select Status to turn the data screen on or off.
    - Select Layout to adjust the number of data fields on the data screen. <== should be single field layout
    - Select a field to change the data that appears in the field <== Single Field
  • Remaining time
    Hi,
    first of all congrats with this amazing datafield. I use it every workout and works great. I wondered if it's possible to add an option in the time datafield to view the remaining time?
