Data Field : Single Field (Legacy : Single Run Field)
*** LATEST VERSION : Single Field ***
Link: https://apps.garmin.com/en-US/apps/1d406424-eec1-4155-85f6-24de6c9611e4
Permission Requirements: User Profile (this is needed to get the HR zones), FIT Recording (used to record snacks earned)
Description: Review app store page for most recent and updated information about the field.
*** OLDER VERSIONS ***
NOTE: Legacy versions support devices which are still currently working and links are found here.
Single Field : https://apps.garmin.com/apps/640d46dd-12db-44d2-acfa-cb7eb9e840b7 (Legacy)
Single Run Field : https://apps.garmin.com/apps/a520cc32-75b2-4b19-a97d-1079b931dc3d (Legacy)
Please use this thread to discuss the single data fields. Links to other support resources for these data fields are listed here:
    Former Member over 9 years ago
    Great field, my number one this time, thank you!
    I noticed one inconvenience with parametrisation. You decided to use percentage of HRMax, instead of absolute HR values to detect and colour HR zones.
    But if I set it exactly as in Garmin Connect (i mean percentages) your datafield zones (colours) and garmin zones are not fully synchronized.
    Example (my HRMax = 193):
    Setting "Max HR Z2" to 77 (the same number i see in GC) I receive "green" colour a few HR bits earlier than on a stock HR gauge.
    Now I try to adjust settings (+-1%) to have it synchronized but it is not always posslible, because 1 percent it is in my case ca 2 HR bits.
    Would it be possible either to synchronize the settings with GC "calculation method" or give possibility of alternative parametrisation (not as percentage but rather as absolute HR values)?
    I don't know if this is already requested, but Garmin changed the cadence zones, can you please adjust them:
  • Thanks for the updated version with TOD/Battery+GPS switch from top to bottom! Any chance you could try to make the font bolder/wider? ;-) Oh and sorry for being picky but could you keep the TOP display regardless of the setting when in the two field/50% display? If not no biggie I'll switch manually when I take part in races where I use the two-field display.
    cadence field
    hi. I use this app daily. feature request. would it be possible to have the option to choose between cadence and average cadence, just like you have with the pace? thank you.
    I would second the request to bold the TOD font. It's amazing how a little thickness to the numbers can help the readability when the font is small like that.
    It's something I thought about from the start but didn't want to get too picky as the dev has been so good with catering to all our requests. But I see others have requested this as well.
    Awesome! I love the TOD at bottom. Not only did you make it happen, you left the option for those who are use to it on top to keep it there. Thanks again for taking the time to make all our watches better tools for running. You are the man!
  • I don't know if this is already requested, but Garmin changed the cadence zones, can you please adjust them:
    This is corrected for the Fenix3/FR630/230/235, I'll get to the others at some point but the adoption of those is pretty low.
  • Awesome! I love the TOD at bottom. Not only did you make it happen, you left the option for those who are use to it on top to keep it there. Thanks again for taking the time to make all our watches better tools for running. You are the man!
    Glad you like it, thanks for the nice review.
  • hi. I use this app daily. feature request. would it be possible to have the option to choose between cadence and average cadence, just like you have with the pace? thank you.
    That is implemented on the Fenix3 and FR630/230/235, others coming in the future.
  • Great field, my number one this time, thank you!
    The goal is to have these things be aligned as best as possible. I only use my field but I can appreciate if a combination of this and a Garmin field is used having the zones/colors match. I'll see what makes the most sense.
