Data Field : Single Field (Legacy : Single Run Field)
*** LATEST VERSION : Single Field ***
Link: https://apps.garmin.com/en-US/apps/1d406424-eec1-4155-85f6-24de6c9611e4
Permission Requirements: User Profile (this is needed to get the HR zones), FIT Recording (used to record snacks earned)
Description: Review app store page for most recent and updated information about the field.
*** OLDER VERSIONS ***
NOTE: Legacy versions support devices which are still currently working and links are found here.
Single Field : https://apps.garmin.com/apps/640d46dd-12db-44d2-acfa-cb7eb9e840b7 (Legacy)
Single Run Field : https://apps.garmin.com/apps/a520cc32-75b2-4b19-a97d-1079b931dc3d (Legacy)
Please use this thread to discuss the single data fields. Links to other support resources for these data fields are listed here:
  • The latest update does not work on my epix with 3.10 firmware.
    I only see iq icon
    Can you message me the contents of the log file from GARMIN\APPS\LOGS\CIQ_LOG.TXT on the device? This will help me figure out what is going on.
    Also, did you make changes to the settings before using it or did if fail before making any changes. If so, where did you make the changes, Garmin Express or Garmin Connect Mobile?
    If your using the 920XT, my test user doesn't use the dark background so I wasn't informed there is no menu option to trigger that. I will add it to the user options for the 920XT and post an update so it can be changed there. If your on the 920XT, does everything else work as expected for you?
    Yes i use the 920xt seems all work ok only can't change the back. color, but tomorrow i go test in the field. Keep the good work and i wait for the update ;) thanks
  • Yes i use the 920xt seems all work ok only can't change the back. color, but tomorrow i go test in the field. Keep the good work and i wait for the update ;) thanks
    Updated to allow background color to be changed from the user settings section. Let me know how it works and hopefully your test run works out well too.
    dunno why but i change the color to black and say settings saved but still in white.
  • Can you message me the contents of the log file from GARMIN\APPS\LOGS\CIQ_LOG.TXT on the device? This will help me figure out what is going on.
    I did changes before using it with Connect Mobile. Sending you the file...
    Please update me when you find a solution, I will try it for you.
    For now I will try to reinstall the field.
  • Problem with the Epix:
    OK, I guess I have found what it is:
    1. I reinstalled the data field - no changes in the settings - it is working.
    2. If I change my Max HR in Garmin Connect Mobile - it stops working
    3. If I change something (or nothing, just open the settings) via Garmin Express - it changes all the settings.
    So I guess the problem is somwhere in saving the settings.
  • i also have iq issue. i try some solution and found as below.
    1. start data filed, it works.
    2. when HR monitor is ready then data filed fail. (show iq icon)
    3. remove HR monitor, it still show iq icon.
    4. quit data filed and restart, it works.
    so i thick this issue is from HR monitor. this is my finding.
  • I believe this is a known issue with data entry through the user settings system. I will put a fix in today to hopefully correct it. I will write here when done so everyone can grab it.
    I have pushed versions which will hopefully correct the issue. I am not seeing the issue being reported so hopefully this will get everyone up and running ...
    Also, if anyone has a FR230/235/630 and would like to try a beta version of that, PM me and I will get you a link.
    After update to Version 0.0.5 still can't change the background color or make any changes and i don't have any file GARMIN\APPS\LOGS\CIQ_LOG.TXT to send you. :cool:
