How to build for ForeAthlete 920XTJ?
Hi,
I've been asked to add support for the ForeAthlete 920XTJ, which I'll gladly do, but I don't know how...
There is no option to build for that device as far as I can see. I'm using Eclipse and SDK 1.1.1.
Anyone know how to do this?
-Torstein
    The different variations of the watches per region are generally due to lack of code space to include all of the language files needed for all languages on a single device. Because of this we wanted to abstract building for each device specifically as the only things we care about are the screens size/colors. The package tool should generate a .prg for each device that supports at least one of the languages you have selected you will support. If you haven't/don't select any languages it should default to building for all the variations.
    Now that that's out of the way, the trick here is that English is listed as a supported language for all devices. If you say your are supporting English you should get a .prg built for the ForeAthlete 920XTJ when you run the package tool with the 1.1.1 SDK if you have the 920 listed as a supported device. I believe there was a bug in previous SDKs where English wasn't included in some of the APAC devices.
    Can you try creating a package with the 1.1.1 SDK and see if there are 006-B1765-00, 006-B2130-00, 006-B2131-00 and 006-B2132-00 folders in the .iq file (those are the 920 variant part numbers)?
  • I updated a few apps last night. I just rebuilt them with the latest SDK and uploaded.
    Thank you, I just created a package, and all the foldesr were present.
