Can I upload my app to my device without publishing?
I just started with Connect ID SDK. I want to upload my own app to my watch for testing, and I do not want to publish it.
Is it possible just upload my app to my garmin watch directly without connect IQ store. I want to test my application first or even I do not want to publish my application and use it only by myself.
I tried to find answer in forum and through documentation, but I could not :(
    Former Member over 10 years ago
    Connect watch with USB, place .PRG file in GARMIN/APPS/ folder
  • I just started with Connect ID SDK. I want to upload my own app to my watch for testing, and I do not want to publish it.
    Basically when you have built a .prg for your device, copy the .prg file to garmin/apps on the device. You see the device as a drive when it's in the charging base. Take it out of the charger, and your CIQ app is there.
  • And where will a watchface prg go?
  • Thank you for your answers. I will try.
    Will it work with watch faces as well or it will work only with applications?
  • I tried, watch faces work as well. I just uploaded *.prg file to the GARMIN/APPS/ folder (near all other apps) and it works!
    Thank you very much to all for answers.
    Also tried and agree, it works.
