Problem getting possible build targets from the devices.xml file
I am just getting started following the steps on http://developer.garmin.com/connect-iq/getting-started/ and can't even create a new project because there are no build targets listed, and I get the console error message, "Problem getting possible build targets from the devices.xml file."
Any ideas what to do? Thanks!
-Ben "Morab"
    Does the path to your SDK contain a space? Today I've been looking into allowing spaces in paths from the Eclipse plug-in down to the SDK and that looks like an error I ran into.
    Still same issue after changing the root folder name to not have spaces, and updating the path in the prefs, however the Program Files folder has a space.
    EDIT: I just moved it into the C drive so there are no spaces in the path, and it works now. Thanks!
    -Ben
    I'm glad you got this figured out. We're working on making the plug-in/compiler play nice with spaces. I ran into some unexpected issues with this today but hopefully this will make it into a release soon.
