Misbehaving recursive functions
I realize that recursive functions are likely to be subject to some limitations, but it appears that the generated code is invalid. Here is a simple example to illustrate the problem.
using Toybox.Application as App;
using Toybox.System as Sys;
function recursive_function(lo, hi) {
Sys.println(Lang.format("lo=$1$ hi=$2$", [ lo, hi ]));
if (lo == hi) {
Sys.println("end recurse!");
return;
++lo;
recursive_function(lo, hi);
class ZebraApp extends App.AppBase {
function onStart() {
recursive_function(0, 3);
function onStop() {
function getInitialView() {
return [ new ZebraView() ];
When I run the program, I see the following output...
Shell Version 0.1.0
lo=0 hi=3
lo=1 hi=3
lo=2 hi=3
lo=3 hi=3
end recurse!
lo=4 hi=3
lo=5 hi=3
lo=6 hi=3
lo=7 hi=3
lo=8 hi=3
lo=9 hi=3
lo=10 hi=3
lo=11 hi=3
lo=12 hi=3
lo=13 hi=3
lo=14 hi=3
lo=15 hi=3
lo=16 hi=3
lo=17 hi=3
lo=18 hi=3
Stack Overflow Error
in recursive_function (source\ZebraApp.mc:5)
in recursive_function (source\ZebraApp.mc:13)
in onStart (source\ZebraApp.mc:19)
Complete
Connection Finished
Closing shell and port
As you can see, the recursion was supposed to end, but it just keeps on going. I've found that if I update the code to terminate the recursion a little differently, the problem can be avoided.
if (lo == hi) {
return;
else {
++lo;
