Howdy!
I've got a pair of apps that run tallies on the amount carbohydrate or fat that is burned during a ride derived from lab test data. I'm using the info.currentPower object to run these calculations, however when an HR monitor disconnect and reconnects it renders the carb/fat total to 0. I'm guessing there's some signal crossing in the ANT+ channel that is causing this? Thanks for any help!
Additional "oddness"... you can only zero it out once in a single acute episode. So if you walk away from the device and come back to it it'll zero out the first time but if you do this again in the time frame of a convenience store stop it will not zero out a second time. Hop back on the bike and ride for another hour and do this again and it will zero out again.
Thanks!
