3.0.11 cannot run simulator - null message
I added in 3.0.10 support for bike computers and upcoming wearables.
Now these are new devices. Now Garmin Connect IQ proeprties opened by Eclipse very long time.
This is due to manifest still holds old valies:
that cause problems:
            <iq:product id="bikecomputer2019"/>
            <iq:product id="wearable2019"/>
Delete from manifest.xml such lines manually. Eclipse SDK cannot do it for you and you will get in trouble when compile and run simulator.
I expect next SDK release will fix this issue.
Top Replies
    Former Member +1
    Hey ,
    Sorry about the confusion and difficulty. Yes, this was not intended, but removing them manually is what needs to be done currently. I found a potentially helpful workaround for those…
All Replies
  • Those were just temporary targets in 3.0.10.  With 3.0.11 you can manually remove them, or you can switch back to 3.0.10 and use "Configure App" to uncheck them.
    It would have been nice if there was a bit cleaner way for this to be handled, but by the next simulator everyone will have probably manually fixed this on their own. (I had to fix about 40 apps myself)
    Hey ,
    Sorry about the confusion and difficulty. Yes, this was not intended, but removing them manually is what needs to be done currently. I found a potentially helpful workaround for those using the Eclipse Plugin:
    1. Open the manifest.xml in Eclipse
    2. Manifest Editor Launches
    3. Click the manifest.xml tab
    4. Unsupported devices automatically deleted
    At this point you should be able to save and compile the project without issue. You may also go back and add the newly supported devices.
    Thanks,
    -Coleman
  • Nice tip thanks! Note I had to click Build Targets tab first, then click manifest.xml tab, then it removed the unsupported devices.
