First off I'd like to say thanks for the dedicated Connect IQ app! The new app is quick, streamlined and modern.
A lot of long-standing issues the Garmin Connect app + CIQ settings seem to have been fixed, such as:
- Losing app settings changes during sync
- Making it too easy to accidentally lose app settings (not prompted to save before exiting settings screen)
- Very slow performance on changing settings
I know that several users were frustrated with some of these issues, even going as far as to recommend using Garmin Express instead. So it's great to see them resolved now.
However, there are a couple of things I've noticed (in the iOS version of the app). Some may be by design, but at least one is a bug IMO:
- If you change app settings, you are prompted to save changes when pressing < (Back), which is great. However, if you swipe right you are not prompted to save changes (changes are silently discarded), which is not so great. This feels like a bug to me.
- Help link is not implemented
- Label text which does not fit within two lines is just truncated, with no way to see the whole thing. Some apps, like the very popular Dozen Run and some of mine (not so popular), use long label text either to provide more information or to separate settings into sections.
- I realize the above usage is somewhat of a hack/workaround, but in the absence of dedicated comment and separator elements, it would be nice if the entire label text was displayed. It seems like this could be achieved quite easily with the current layout, since the label height already seems to be dynamic (between 1 and 2 lines + the value) -- if the max height could be unlimited instead of 2 lines, that would be great.
- It would also be nice if newlines were rendered within the label, as they are in the simulator. It would help in the case when newlines are used for cosmetic purposes (for sections and/or breaking up descriptive text)
Thanks for reading!
