Strange - I wrote a data field that writes User Data to the FIT file. Works great. But apparently it only writes when the data field is on the active screen. Ugh. I understood that data fields run continuously even if assigned to a screen that isn’t the one currently showing. Is there a trick to keep the data field running and writing to the FIT file when on a screen that isn’t showing?
