Garmin Express 6.12.0.0
Garmin Connect (iOS) 4.15.1.2
iOS 12.1.4 - iPhone 6S
Description of Problem
Garmin Express and Garmin Connect iOS have different string imits: 256 chars and practically unlimited, respectively. I don't know what the limit is on GC Android, although I would be very interested to find out.
I understand the need for practical limits, but it would be nice if they were the same on all platforms. For certain applications (formulas and encoded config from outside sources), I think 256 is too small, and 1024 would be a nice compromise. Strings up to at least 2048 characters certainly work in iOS (and on the device), as demonstrated below.
The actual practical limit (maybe at the Monkey C level) seems to be between 2048 and 4096 characters (also demonstrated below).
Recreation Procedure
1) Download Training Notes data field app and install it: https://apps.garmin.com/en-US/apps/e...9-fe49891d7e76
(I installed it on an FR935)
2) In Garmin Connect iOS, open Training Notes app settings:
Enter 2048-character string for Line 1. A 4096-character string also works, but the app can't seem to handle it, so I don't want to muddy the waters. The limit beyond which this app will display nothing instead of something (part of the string) seems to be somewhere between 2048 and 4096.
Note that this string begins with "2048BEGIN" and ends with "END". These substrings do not occur anywhere else in the string.
2048BEGINAAAA00123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A01000123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A010END
3) Verify that app displays part of this string, on the watch.
4) In GC iOS, open app settings again.
4a) Verify that first part of "Line 1" string says "2048BEGIN"
4b) Double-tap on "Line 1" string so you can see the end. Verify that the end says "END", so you know the whole string was stored
5) Connect watch to Garmin Express.
5a) Open Training Notes app settings
5b) Note that while the entire string is visible, the text field prevents the user from adding or modifying any characters past the 256 character limit. The user is able to delete characters, though.
5c) Delete the entire string
5d) Paste in the 2048-character string again. You will see that the string gets truncated. If you copy the string and paste it into Notepad or a similar text editor, you should see that the truncated string is exactly 256 characters.
Notes
Here is a 4096-character string, in case you wish to test the case where a 4096-character string will be stored in settings, but not "accepted" by the app (which will just display a blank string instead).
As before, the end of the string has the characters "END".
4096BEGINA100123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789aA0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A01000123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A010END112342044BEGIN00123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A01000123456789A0123456789A0123456789A0123456789A0123456789A012345678A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A012456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A0123456789A01330END
