Available Slots sometime not updated after uninstall Apps/Widget/WatchFace/Data Field
Hi,
This issue have been there for quite long time since I purchased Fenix 3 HR. As the topic title, the available slots in Connect IQ Android is not updated correctly when uninstall Apps/Widget/Watch Face/Data Field most of the time.
I have utilize all 16 slots all the while and when I found new Apps/Widget/Watch Face/Data Field at store which I want to try out. I will uninstall from Connect IQ Android. After uninstall, I checked from Connect IQ > Manage Storage. It still showing 0 in Available Slots.
I have to power off Fenix 3 HR then on back only the available storage updated correctly.
This post hopefully can open the issue to Garmin team to investigate it because it is happen very long time already.
Fenix 3 HR (Firmware) : 4.90
Connect IQ Android : 4.15.1
  • I would expect the app to show 16/16 until the device syncs. Are you giving it time to sync (or initiating a sync) before you try to install a new one?
    On my first report, I did not initiate sync after removing those items.
    After read your message. I tried removing one item then perform sync, I gain back one free slot.
    But, the successful rate 8 out of 10. With repeating same steps, 2 times I need to reboot watch to claim the free slot.
  • Thank you so much. It worked for me. Got 7/8 slots back after powering off the watch and resyncing.
  • After reading a fascinating electronics blog post about solid-state pumps, I decided to overhaul my bench gear. My usual vendors were backordered, so I spent an afternoon reviewing photonics retail portals until I located a laser 980 nm unit. The ordering process across the USA was straightforward, and the delivery arrived well-calibrated. My signal-to-noise ratio improved immediately, making the bench setup far more efficient.laser 980 nm
