Garmin Connect IQ and different app fields in pc and phone
hi
i have problem with Garmin Connect.
I have installed Garmin Connect in my android phone and in my desktop pc.
When i syncronize my Garmin 520 in phone i see all app fields installed.
But when i syncronize my Garmin 520 with Garmin Express on pc i see less app fields and not the sames of phone.
Why this ?
i use last version of Garmin Express..
  • Are you talking about the number of apps or are you talking about app settings? Maybe you can attach screen shots which demonstrate the difference? I'm not too sure what you are meaning.
    ok. this is phone and desktop pc.
    and in my pc i cannot setup any data field installed...
    I have installed different Appbuilder version and in my phone i can modify formula and setup, in my pc i cannot modify.
    it's normal this ?
    community.garmin.com/.../1459689.png
  • That is a strange one, and certainly not something I've seen before. Neither phone nor PC should display apps without the device being connected, but it's almost as if they are seeing different things. I assume that both say that they are synced correctly? My only suggestion would be to delete all apps, and make sure that both the PC and phone show nothing installed, then start again. If that did not work, my next option would probably be a reset. Did you try a device power cycle?
