Widget Settings not Visible when Installed on Device
I've added a handful of settings to my widget in properties.xml. They show up just fine in the App Settings Editor:
The widget reads the settings just fine in the emulator, both for default and altered values, and when deployed to my Vivoactive 3, the widget runs fine, showing all the behavior I'd expect with the default values (including pulling data from the default URL, which is only ever defined as a setting default). However, neither the Garmin Connect app nor Garmin Express show any way to configure the widget once it's deployed to the device:
Is there something I'm missing in my XML? The whole project folder is available on my Github page, in case anyone wants to take a look at how it's set up. I'd also be more than happy to copy/paste any relevant files into this thread, or provide the compiled app that's running on my watch.
  • You can't use app settings with a sideload. You can only use them if you install from the app store.
    You'll find some about this in the New Developer FAQ, but there was also a change so you can upload an app to the store and mark it as "beta", so only you can download it and check out things like app settings.
    see This app is for testing only
    For app settings be sure and look at point 10 in the New Dev FAQ, as that's a common problem.
    Sorry I missed your response, I guess email notifications were turned off. I'll try submitting to the app store and working from there. Thanks for the help!
