Vivoactive HR crashes when swiping connectIQ widgets.
  • The Environment:
Vivoactive HR SW version 5.0.0
ConnectIQ SDK version 3.0.8
SDK Target version 2.4.x
  • Eclipse Version
Version: 2018-12 (4.10.0)
  • A detailed description of the issue
When attempting to swipe on the UserProfile sample application if there is any downward slope to the swipe you see the ui shift down with the downward swipe, and then it shows the proper UserProfile view. Once that happens, if you attempt to swipe again, the watch will crash.
  • Steps to reproduce the issue
  • Install the UserProfile sample application to the watch
  • Swipe to the UserProfile widget.
  • Swipe Left and slightly down. You will see the ui briefly shift down and then it will render the proper UserProfile view.
  • Attempt to swipe left again
  • A code sample that can reproduce the issue (in email only if preferred)
You can see this error with the UserProfile sample application provided by the SDK.
  • Does the app crash with "IQ!" or does the watch itself crash?
  • We looked at this briefly today and weren't able to see any crash using the steps you have. Could you provide some more details? especially on step 3 of your reproduction steps? If we swipe to the left at an angle down, the widget looks like it is trying to move to the next widget which results in the breif ui shift. But then if we try to swipe left again, it works as normal.
    Also if it's a app crash could you check for a crash log in devices GARMIN/apps/logs folder, and if device crash in the GARMIN/debug folder.
