Problem with app properties suddenly using up lots of memory?
Has anyone come across a problem when running an app in the simulator (a watchface) that when they add one new property then the memory used by application settings in the simulator suddenly increases massively?
I don't even need to add the property as a setting for this to occur. And if I remove that property (or even a different property) then the memory usage suddenly drops back to normal again.
Maybe I am hitting a soft limit of some kind? I currently have 102 properties and the problem seems to occur when I go to 103 properties.
In the simulator memory usage view my normal <Application Settings> size is 2384(3949).
When I add the one extra property then the <Application Settings> size jumps to 9404(10981) by more than 7k!
And this has the unfortunate effect of making my watchface stop working when I try and change settings from the settings editor as there is no longer enough memory available in the app!
