*** Resolved ***
Hi, I have just managed to install the Connect IQ plug-in into Eclipse and have created my first app but I cannot open the Garmin simulator, either through Eclipse nor directly from the Windows file system. In Eclipse, I get the following error message:
Failed opening simulator.
Cannot run program "C:\Eclipse\garmin\connectiq-sdk-win-3.0.7-2018-12-17-efeb3e3\bin\simulator.exe" (in directory "C:\Eclipse\garmin\connectiq-sdk-win-3.0.7-2018-12-17-efeb3e3\bin"): CreateProcess error=5, Access is denied
I am logged in with an admin user so should not be a problem with user rights. In the file system, I get this:
"Windows cannot access the specified device, path or file. You may not have the appropriate permissions to access the item"
I am running Windows 10, could it be some security setting that prevents me from executing this file? Perhaps the certificate that signed the application is not trusted by the operating system? When I downloaded the SDK through Eclipse I got an option to accept some certificate so that should be taken care of I guess? I really have no clue. I tried remove and re-install eclipse and the Garmin SDKs but didnt help.
Im running the SDK version 3.0.7.
Thanks!
