BUILD: ERROR: Das System kann den angegebenen Pfad nicht finden
BUILD: java.io.IOException: Das System kann den angegebenen Pfad nicht finden
BUILD: at java.io.WinNTFileSystem.createFileExclusively(Native Method)
BUILD: at java.io.File.createNewFile(Unknown Source)
BUILD: at com.garmin.monkeybrains.Monkeybrains.writeDebugXml(Monkeybrains.java:313)
BUILD: at com.garmin.monkeybrains.Monkeybrains.runPRGCompiler(Monkeybrains.java:1428)
BUILD: at com.garmin.monkeybrains.Monkeybrains.compileApplication(Monkeybrains.java:1022)
BUILD: at com.garmin.monkeybrains.Monkeybrains.run(Monkeybrains.java:2219)
BUILD: at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:252)
BUILD: at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:234)
BUILD: at com.garmin.monkeybrains.Monkeybrains.main(Monkeybrains.java:281)
BUILD: usage: monkeyc [-a <arg>] [-d <arg>] [-e] [--Eno-invalid-symbol] [-f <arg>] [-g]
BUILD: [-h] [-i <arg>] [-m <arg>] [-o <arg>] [-p <arg>] [-r] [-s <arg>] [-t] [-u
BUILD: <arg>] [-v] [-w] [-x <arg>] [-y <arg>] [-z <arg>]
BUILD: -a,--apidb <arg> API import file
BUILD: -d,--device <arg> Target device
BUILD: -e,--package-app Create an application package.
BUILD: --Eno-invalid-symbolDo not error when a symbol is found to be invalid
BUILD: -f,--jungles <arg> Jungle files
BUILD: -g,--debug Print debug output
BUILD: -h,--help Prints help information
BUILD: -i,--import-dbg <arg> Import api.debug.xml
BUILD: -m,--manifest <arg> Manifest file
BUILD: -o,--output <arg> Output file to create
BUILD: -p,--project-info <arg>projectInfo.xml file to use when compiling
BUILD: -r,--release Strip debug information
BUILD: -s,--sdk-version <arg> SDK version to target
BUILD: -t,--unit-test Enables compilation of unit tests
BUILD: -u,--devices <arg> devices.xml file to use when compiling
BUILD: -v,--version Prints the compiler version
BUILD: -w,--warn Show compiler warnings
BUILD: -x,--excludes <arg> Add annotations to the exclude list
BUILD: -y,--private-key <arg> Private key to sign builds with
BUILD: -z,--rez <arg> Resource file
BUILD: Complete
Aborting launch due to failed build.
