I assumed that if some lines are missing in the language strings.xml file located in resources-xxx\strings, then these lines will be loaded from the main strings.xml file located in resources\strings. And it actually works that way when setting up in GCM. However, when you try to open a settings in the App settings editor, it freezes.
