I verified that this works as expected for C, Java and JS files in Eclipse.
Environment:
Windows 10
Eclipse 2018-09 (4.9.0)
CIQ Plugin 3.0.6 (latest)
CIQ SDK 3.0.7
Test data:
System.println("line 1");
x = 42; // line 2
System.println("But what's the question?"); // line 3
System.println("line 4");Test Case Summary / Expected Behaviour:
After selecting some code and pressing CTRL-/ twice, the code should be unchanged.
Test case 1:
(select mix of lines with/without comments)
1a) Select all lines
1b) or Select line 1-3
1c) or Select line 2-4
2) Press CTRL-/ twice
Result: PASS
x = 42; // line 2
System.println("line 4");Test case 2:
(select only lines with comments)
1) Select lines 2-3
Result: FAIL
//x = 42; line 2
//System.println("But what's the question?"); line 3
System.println("line 4");Now if you try to uncomment lines 2 and 3, you've got invalid code that doesn't build. Or if you had only pressed CTRL-/ once in the first place.
Test case 3
Repeat test case 2, but only select line 2. Similar failed result.
Test case 4
Repeat test case 2, but only select line 3. Similar failed result.
