UT time to a moment...
I'm getting a UTC time from a website in one of my apps, and simply want to convert it to be displayed in CIQ ( it's unix based on epoch "seconds").
I convert it to a moment using "var now = Calendar.moment( {:seconds=>timestamp} );"
and when I go to display it using the .info method in Gregorian, the year and month are correct, but DOW and day are one behind, and the time is always "17:00:00".
If I mod the number with 86440 (sec's in a day), and just look at the times, it's STILL 17:00:00!
This isn't a local vs UTC issue, as UTC is ahead of me, not behind.
Is this a bug, or just me being stupid?
    Former Member over 10 years ago
    Join the stupid club? I tried to convert a timestamp to a moment. If I remember rightly it always came back as something like 11:00 in 1998
  • It sounds like you're being bit by the Garmin epoch offset. This post might shed some light on the issue.
    Try fill the other dictionary values by 0
    options = { :second => unixtimestamp, :hour => , :minute => 0, :year => 0, :month => 0, :day => 0};
    czas = Calendar.moment(options);
    I'm uset this in calendarwidget and I have only utc/dst issues.
    Doesn't work for me. Incidently we have just come off daylight savings time, so my memory was correct, just slightly dyslexic, eg would have been 1989 11:00
    function onStart() {
    var utc = Time.now().value();
    var options = { :second => utc, :hour => 0, :minute => 0, :year => 0, :month => 0, :day => 0};
    var moment = Calendar.moment(options);
    var date = Calendar.info(moment, 0);
    System.println(format("$1$-$2$-$3$T$4$:$5$:$6$",[
    date.year,
    date.month,
    date.day,
    date.hour,
    date.min.format("%02d"),
    date.sec.format("%02d")]));
    1989-12-31T10:00:00
  • I'm only running in the simulator right now (haven't tried on a real device, and there the year is 2015, but the date is a day off, and time is always 17:00. Here's println output of the timestamp moded with 86400, and the resulting time. you can see that the "seconds" are 300 seconds apart (5 mins), and it's doing this based on a 5 minute timer.
    44069
    17:00:00
    44369
    17:00:00
    I've changed the dictionary to be (only had :second before)
    {:second=>secToday, :hour => 0, :minute => 0, :year => 0, :month => 0, :day => 0} and it's "different", but still odd.
    44972
    23:28:16
    The time is always the same, while secToday is changing. Just tried it on a vivoactive, and I get the same time (23:28:16)
    The :seconds option (and other options) Toybox.Time.Gregorian.moment API does not accept full offset values. The current implementation is only going to work properly with seconds = [0..59].
    If :year, :month, :day are not specified, it will set them to the current day/month/year.
    We have corrected some of the issues with dates prior to 1990, but I don't think those fixes have rolled out into the SDK or products yet.
    If you want to create a moment with a UNIX timestamp, it is possible to create a new Moment object with that value.
    [e.g. var time = new Toybox.Time.Moment( timestamp );]
  • @brian - just tried as you suggested, but it seems to think something other than "UNIX epoch" in the simulator, as the moment has 2126 as the year!
    Can you post a sample of the code you are running? The constructor saves the value directly, so I don't know what could go wrong in that case.
  • Here ya go. ("epoch" is the value for the "epoch tine")
    Sys.println(epoch);
    var now = new Toybox.Time.Moment(epoch);
    var today = Calendar.info(now, Time.FORMAT_SHORT);
    Sys.println(Lang.format("$1$ $2$ $3$", [today.month, today.day,today.year]));
    Sys.println(Lang.format("$1$:$2$:$3$",[today.hour, today.min.format("%02d"),today.sec.format("%02d")]));
    And the results are:
    1428567577
    2 5 2126
    23:28:16
    update. if I use now=Time.now() to get the local tome, and display it (now.value()) , it's with a few hundred second of the "epoch" value I display above. And using the same code for "now" as shown above, it results in the same data and time.
    The Moment constructor isn't working the way I would expect it to, so I guess that isn't working right now.
    I'm not finding a good way to do this at all. I've filed a ticket for not being able to create a Moment from a epoch offset.
    If you can break your offset down into year/month/day/hour/minute/second, I guess you can use Gregorian.moment, but that kind of completely defeats the purpose.
