Device type: Fenix 5 Plus (Simulator)
Error:
Failed invoking <symbol>
Unexpected Type ErrorThe error above is generated when adding a single map marker using the code below:
var coords = new Position.Location({:latitude => 38.85695, :longitude => -94.80051, :format => :degrees});
var defaultMarker = new WatchUi.MapMarker(coords);
defaultMarker.setIcon(WatchUi.MAP_MARKER_ICON_PIN, 0, 0);
MapView.setMapMarker(defaultMarker);To suppress the error, I send the defaultMarker in an array as so:
MapView.setMapMarker([defaultMarker]);The API docs state that an object or array should work. The example shown on the developer site also illustrates a single marker being passed:
https://developer.garmin.com/connect-iq/programmers-guide/user-interface/#mapmarker
