CIQ error DataFields RunScribePlus & StrydPower
forerunner 935 firmware 1157 beta
datafields RunScribePlus & StrydPower together in one treadmill activity application
both datafields connect to their sensors through their own ANT+ connection [no need to pair sensors, just provide sensor ID in GE, GCM setup]
Starting the treadmill activity always causes for one of the datafield a CIQ! error.
Is it possible to even have these two datafields running together. CIQ design specific?
Do these devs have to talk to each other solving, checking the error ?
happy hunting
Error: System Error
Details: 'Failed invoking <symbol>'
Time: 2018-12-10T19:56:03Z
Part-Number: 006-B2691-00
Firmware-Version: '11.57'
Language-Code: eng
ConnectIQ-Version: 2.4.2
Store-Id: c1f5c80a-5a05-4e8a-97b3-fda34e957035
Store-Version: 28
Filename: 87CC1E35
Appname: RunScribe Plus
Stack:
pc: 0x10000a9a
pc: 0x100007d6
pc: 0x1000051c
Error: System Error
Time: 2018-12-10T19:58:53Z
Language-Code: eng
ConnectIQ-Version: 3.0.4
Store-Id: 660a581e-5301-460c-8f2f-034c8b6dc90f
Store-Version: 50
Filename: DFD0C7C6
Appname: Stryd Power
Stack:
pc: 0x10000505
    Former Member over 6 years ago
    forum is teasing me not uploading my pics :cool:
    have a look at this .... overview developer fields
    FlowState, your wasting space line does not match the FIT layout
    for your information
    space for the field names is always reserved in every fit file containing developer data ;)
    FlowState, your words, "That field name you're looking at in whatever tool that is seems to be based on the field number, anyway."
    have a look at this ... fit file content viewed with hex viewer
  • Why don't you try fittocsv in the Fit SDK It makes the fit file much easier to understand.
  • I'll just post some examples of field names that Dozen Run writes:
    eE
    rE
    pwr
    tpRE
    FellrnrRE
    I'll just say they are clearly not meant to be displayed. And if any of them corresponds to a built-in field, they better use a native field number so 3rd party sites will know.
    Sorry for my previous, now-deleted remarks. I guess it's frustrating when trying to explain something to someone and you're not believed. But my responses were inappropriate.
    Yes, it is possible that 3rd party sites could look at a known field name for a popular app, especially if it's a non-native field like "beers consumed" or something. But a best practice for a native field like Power would be to use the native field number.
    I would also suggest using fittocsv. I think you will find that most, if not all, 3rd-party apps that write power will use the native_field_num. With a value equal to 7, 19, 20 or 21, depending on whether it's a record, lap or summary, and what kind of power it is: current, average, min, max.
    If not, then I apologize for spreading misinformation. It wouldn't be the first time.
    Thank you FlowState for sharing your knowledge in a civilized manner.
    Solved : third parties know what to do with the data according to the FIT specifications
    Now going back to the main part of the original post.
    Using two datafields at the same time, one from runscribe light and one from stryd power in the same workout.
    Developer field names for runscribe light are empty.
    Developer field names for stryd power are populated.
    Using those datafields on their own in a single workouts.
    Developer field names for runscibe light are populated.
    thank you again FlowState for cleaning up and I appreciate your commitment with my grey cells
    When you look at the previous posted screenshot from the FFRT tool,
    you will see that all the info you talk about is there in that screenshot.
    Being the field names and their corresponding numbers.
    My main concern was the lack of populated field names from this combined FIT file (runscribe and stryd).
  • I see. I apologize for missing the primary point of your post (I had a feeling that I did). Didn't really get any sleep last night. It's great that you're doing all of this testing. That's a lot of commitment, effort and attention to detail that most people wouldn't go through.
    I suppose I focused too closely on your comment about internal names versus GC names versus how 3rd party sites interpret the data. In any case, that doesn't excuse my previous reaction, and none of that stuff is important, anyway.
    If those fields are blank, my educated guess is it has to do with the crash you described earlier.
    Hopefully Garmin, Stryd and Runscribe appreciate what you are doing.
    Stryd asked info and is investigating.
    No news from RunScribe.
  • Thank you OnlyTwo & FlowState for the great work you are doing. I am also trying to make Stryd & RunScribe work together on the same Fenix 5x, for now without success.
    I did several tests and evaluated the tables generated on golden Cheetah.
    I have a question to ask, if I use Stryd & runscribe light, what data I'll see on WKO4 +.
    Thanks.
