Two downsides to using links
I have encountered two downsides to using links to share code between apps:
  • The Eclipse/SDK Debugger fails to find the linked file, see attached screenshot.
  • GIT, not surprisingly, commits the link address, not the file, so the shared code has to be archived separately.
So it's still very useful, but needs careful handling.
community.garmin.com/.../1429290.png
  • Does anyone know why my image, a 200kB JPG file, which was captured from a 20x15 cm area of my screen and which displays as this size in my browser, appears as an unreadable 10 X 6 cm image in the Forum.
    Or more to the point, what can I do to paste screenshots which are such a powerful method for explaining issues?
    So I'm trying imgur
    https://imgur.com/a/dLZLTlt
  • I'm not sure. How exactly are you uploading the file? I typically click the attachment button on the top-right of the 'Write something...' field.
    That option takes me to a file select dialog, and when I select a png or jpg file it returns a fail box with "Error uploading image".
    When I take the option in the bottom left "Share photos" the file select and upload works, but the image is unreadable, as you see above 1/2 width, 1/2 height.
    Platform Mac desktop, MacOS Mohave.
  • I think once you upload a certain amount of images (all-time!), the forum either starts limiting the size or blocking image uploads completely.
    For some reason, it wants to add the images you upload to a personal album which has a limited size (depending on which method you use to attach images), instead of just embedding images in individuals post.
  • When you upload the image, just after uploading it there are links generated at the bottom (thumbnail / small/ medium / large / full size), when you do not select any of the links it defaults to the smallest size.
    Personally I prefer choosing an external image host and then include the image in within the img bbcode. (External image hosts have the downside that images may get deleted after a number of months without views though so there's also a downside to choosing this path)
