displayInActivityLaps does not work?
i'm trying to show values in the lap activities.
i have 1 fit contributor for the graph
<fitField id="3" displayInChart="false" sortOrder="0" precision="0"
dataLabel="@Strings.totpassi_graph_label"
unitLabel="@Strings.totpassi_units" displayInActivityLaps="true"/>
and another for the activity laps
<fitField id="0" displayInChart="true" sortOrder="0" precision="0"
chartTitle="@Strings.passi_label" dataLabel="@Strings.passi_graph_label"
unitLabel="@Strings.passi_units" fillColor="#FF0000" />
after start the session, i init a variable for the graph
mPassiField=session.createField(
"passi_label",
PASSI_FIELD_ID,
FitContributor.DATA_TYPE_UINT16,
{:mesgType=>FitContributor.MESG_TYPE_RECORD, :units=>"N"});
mPassiField.setData(0);
mTotPassiField=session.createField(
"totpassi_label",
TOTPASSI_FIELD_ID,
when i add a value to the graph,
mPassiField.setData(stepsParz);
i add the same value to the activity
mTotPassiField.setData(stepsParz);
and then add a
session.addLap();
the result is that i see the values on the graph but i don't see values in the activity laps.
what i do wrong?
thank you
Federico community.garmin.com/.../1423936.png community.garmin.com/.../1423937.png
  • I noticed the same thing -- I think there's a bug with the GC app right now. Try the Garmin Connect website (which works for me).
    Former Member over 6 years ago
    two or three GC App updates and nothing is changed ?!...
    What version of GCM are you seeing this with and are you seeing this on iOS or Android?
    Thanks,
    Kamau
    the system is Android.
    the version 4.13.5
    the version is
    Thanks,
    Kamau
    Thank you! We've created ticket Weretech-6257 to take a look.
    Thanks,
    Kamau
    TMFWatches, are you seeing the data on Garmin Connect web but not in Garmin Connect Mobile (to confirm) and can you please send us a fit file for the activity so we can try to reproduce this issue on our end?
    Thanks,
    Kamau
    Thanks,
    Kamau
    No, on Garmin Connect web i cannot see the data too.
    TMFWatches, thank you, added this information to your ticket.
    Thanks,
    Kamau
    TMFWatches for the activity,
    "totpassi_label",
    TOTPASSI_FIELD_ID,
    :mesgType try FitContributor.MESG_TYPE_LAP instead of MESG_TYPE_RECORD
    Please let us know if that fixes it.
    yes, it work now.
    thank you
    "totpassi_label",
    TOTPASSI_FIELD_ID,
