Hello:
I can see in my Edge 520 that there is a limit of 4 ConnectIQ fields. Is this limit for technical reasons? Is 4 the limit in the entire Edge series? Is planned another limit greater than 4 in future versions?
There is a technical reason I'm sure. As far as the limit, I "think" the E130 only allows 2, while the E1030, 10. Most watches, a limit of 2.
Will that change? doubtful. New devices, who knows. (well, maybe some garmin folks! :) )
The other thing to consider is the memory available for CIQ DFs. On CIQ1 devices, they can only be 16k. The E520, 32K, the E1030, 128K...
The Epix actually had a limit of 3 fields, the only watch I know of that allowed more than 2. But there were some bugs around the number you could install.
The Edge 130 has a two field limit as Jim says. Until recently, you could only have even 2 installed on the device at a time. I believe one of the later firmwares removed that limitation but you can still only show 2 at a time. Also, the 130 doesn't allow for apps.
Almost guaranteed the limit is there generally to limit the total resources used by CIQ data fields. With the 10 field limit on the 1030, not sure if there is combined memory limit lower than 10 x 128k. I guess they may also limit the number of fields for marketing reasons as well. I'm somewhat surprised they didn't up the limit to 3 or 4 with the Fenix 5 Plus versions.
