I would like to create note on my Fenix3 / How to get key event
I've would like to put some notes on my Fenix3, But there's no any note app and it didn't support my language.
So I decide to create widget to show my note I chose to make note as picture.
I've try it with basic widget, add picture and edited a little line of code so I can make I show the note.
But only one page.
I would like to get key event to move to another page of note.
such as
//When Key is press
screen1 = screen1+1;
if(screen1>4){screen1=0;}
if(screen1==0)
setLayout(Rez.Layouts.MainLayout(dc));
if(screen1==1)
setLayout(Rez.Layouts.MainLayout1(dc));
if(screen1==2)
setLayout(Rez.Layouts.MainLayout2(dc));
if(screen1==3)
setLayout(Rez.Layouts.MainLayout3(dc));
if(screen1==4)
setLayout(Rez.Layouts.MainLayout4(dc));
Here's my code.
using Toybox.WatchUi as Ui;
var screen1;
class testtView extends Ui.View {
//! Load your resources here
function onLayout(dc) {
screen1=1;
//! Restore the state of the app and prepare the view to be shown
function onShow() {
//! Update the view
function onUpdate(dc) {
// Call the parent onUpdate function to redraw the layout
View.onUpdate(dc);
//! Called when this View is removed from the screen. Save the
//! state of your app here.
function onHide() {
And more question
Can I load my widget to my Fenix3 without put it to store. If I can how to do that?
Thanks
  • Here u find the answer on your last quistion, unfortunately I can't help u with the first quistion. I sure someone els will help u with the rest ;)
    https://forums.garmin.com/showthread.php?231358-Connect-IQ-Questions
    read #2
    Thank, I've tried load app to watch. It's OK
    still find how to get push button event
    found that in some thread, they create new class.
    class AlertPickerDelegate extends Ui.InputDelegate {
    function initialize(hilo, persist, view)
    function onKey(evt)
    function onTap(evt)
    function increment(inc)
    So I tried add class.
    class testtViewDelegate extends Ui.InputDelegate {
    function onKey(evt)
    if(screen1==0)
    if(screen1==1)
    if(screen1==2)
    if(screen1==3)
    if(screen1==4)
    But it didn't work. Is there anything I need to do more to make it know about the button event?
    A little more question
    In simulator, can I press watch button?
  • You need to tell the framework that you have an input delegate. The array returned from getInitialView() should have a second value that is the input delegate.
    All of this is covered in the example programs and in the users guide. You should take a break from coding and do some reading.
    Thanks, I've just found that example are in sdk folder. I tried to find them in dev website.
    Now It's Done. Thanks.
