Average Power from Stryd Sensor with F5x+ and the builtin RUN app
I've been working to include STRYD data into my Data field Dozen Run, both Average and Current Power work in the simulator. However in the hardware the info.currentPower is OK but the info.averagePower is not showing and returning as a NULL. Not sure if this is a Watch issue or a IQ SDK issue I will post to both in hopes that it gets resolved.
    Have you tried using it through one of the datafields built by STRYD? They had a datafield and their sensor around since before running power was a thing so they were probably using a generic channel to get the info and doing STRYDy things in their app or DF before writing to the fit file. I guess I'm saying that I'm not sure what the sensor is actually giving the device. Are you testing with a STRYD pod in the sim or is this simulated data? Is it from a fit file? It would make sense to me that it's returning null if that data is not being provided. Let us know what you find here.
    Thanks,
    -Coleman
