On garmin edge 820 with Firmware 10.00 it seems the info-objects itself or one/some of the methods info.currentLocation, info.currentHeading or info.elapsedTime are broken.
There are two IQ-Apps I use regularly on the 820: TileExplorer and EveryTile. Both do not work properly with FW 10.0, but did with FW 9.10.
Both show the actual route in a map-like canvas (just squares for map-tiles) and mark all the map-tiles you have covered on this trip.
both, since 10.0, show the sqaures, but no route/trip and show no movement, when the edge 820 move.
It seems, both apps don't get trip or GPS-information.
Tried today downgrade to 9.10 - works fine
Update to 10.0 - no movement, not trip visible
From the source-code of EveryTile ( https://github.com/to-ko/EveryTile/b...eryTileView.mc ) I suppose there might be a change in 10.0 with the info-object or with one of the methods info.currentLocation, info.currentHeading or info.elapsedTime.
But that is just a guess from a quick view on the source code.
