WebRequest sample crashes instantly on VAHR emulator
Hello, I am having a problem with makeWebRequest with JSON response (only first request when the app is first run passes through, all subsequent requests end up with code -400) and I wanted to try a simplest example first.
So I tried WebRequest sample from SDK 2.4.9 and 3.0.2. The weird thing is that for both of these, my VAHR emulator crashes instantly after pressing the menu or select button. When I select a different device (like VA3), the simulator runs perfectly - but the problem is that my real app has problems on VAHR too, so I wanted to first debug a minimal working sample on VAHR.
Could you please verify?
  • You using the sample as is or with a different url?
    Does the sim crash or does the app crash?
    The sample is a widget, so a limit of 60k on both a vahr and va3, so are you seeing that the peek is close to that on a va3? (Sim's File>View Memory).
    Just tried one of my widgets that does makeWebRequests (two back to back) in the 3.0.2 sim with both vahr and va3 as targets and no problem, but the peak usage is well under 60k.
    BTW, there is a neat feature in the CIQ3 sim - "View HTTP Traffic"
