getProperty throws compiler error on E1030 Bontrager only - 3.0.1 SDK
  • The Environment: win10, 3.0.1 SDK, Eclipse Oxygen
  • A detailed description of the issue : when compiling a widget that uses getProperty, and error is thrown but only with the E1030 Bontrager as a target. Other targets compile and run fine
Could not find symbol getProperty.
Symbol Not Found Error
in readKeyInt (C:\Users\James\workspace-prod\WUWid2\source\WUGwidView.mc:138)
  • A code sample that can reproduce the issue (in email only if preferred)
I did this with my WU Widget, just because it was handy, but this can likely be seen with anything that uses getProperty and the E1030 Bontrager can be set as a target (the ObectStore sample?)
