setting required=false alphaNumeric string setting back to blank gets "Try again"
so... i have an app (CGMLoop) in the store, and when I use it on my phone with Garmin Connect and try to change an alphaNumeric string setting from non-blank to blank Connect just says "Try again" and doesn't let me set it.
the required flag is false, so as i understand it users should be able to set it back to blank... do i understand wrong? (the app settings in simulator allows setting it back to blank, fwiw).
from settings.xml:
<setting propertyKey="@Properties.nsurl" title="@Strings.nsurl" prompt="@Strings.nsurlPrompt">
<settingConfig type="alphanumeric" required="false" /></setting>
