I have some ANTUSB2 sticks that work fine with SimulANT+ and ANTWare II.
I wanted to test some examples that use HRM data in the smulator. When the simulator starts up it displays "ANT USB0 0 connected" which I assume means it can see the ANTUSB2 stick.
When I run the sample code it cannot see the real HRM's I have, the HRM field is static. If I use the menu option "Simulation | FIT Data | Simulate Data" then the HRM field comes to life in the App.
Any suggestions as to what might be going wrong, it seems some people have this working but there is no set up information in the docs so I guess its "just supposed to work"
Thanks for any help,
Nick
