I'm still very new to Eclipse so not sure if these are Connect SQK specific or Eclipse specific annoyances, but thought I'd throw them out there and see if anyone has had similar experiences and knows of a way to stop them.
1. At least 10 times a day I accidentally press the Run > Run menu option whilst a .xml config file is the active document in Eclipse. This causes a build failure, the creation of a .out.xml file which I have to delete and a history entry in the run configurations which will re-run the next time I press Run > Run unless I first manually select the correct run profile. This is driving me round the bend. Is there any way to prevent it?
2. The export wizard and the build for device wizard have both somehow latched on to a default folder path for exports, which is the first folder I exported to in each dialog, respectively. Both are pointed to old non-existent folders rather than a more useful default of the most recent export folder I used. Is there any way to make it remember my last export folder, or at least reset the default to something more useful?
