Display Temperature on Edge 1000 DataField
I'm working on a (complex) datafield for the Edge 1000 and one thing I'd like to display is the temperature from the internal sensor.
I've read conflicting things about whether this is even possible - ie that it can be done but you must create a background process that runs every five minutes or something... but all this information is a few years old so I'm not sure if anything has changed.
One issue I'm having with anything I try is that I get a pair of "Permission required" errors when I attempt to run the app in the simulator. I have enabled the permissions in the manifest (Background, Sensor History, and Sensor).
In the initialize function declaration I'm also enabling the sensors like so:
function initialize() {
DataField.initialize();
Sensor.setEnabledSensors([Sensor.SENSOR_TEMPERATURE]);
Sensor.enableSensorEvents(method(:onSensor));
mValue = 0.0f;
speed = 0.0f;
batteryPercent = 0;
temperature = 0;
What am I doing wrong here? Is there anything that can even be done to achieve what I'm looking for, or is it impossible to get the temperature in a custom data field on the Edge 1000?
  • Read the question wrong, so corrected answer:
    In a DF, you can't access Sensors in in the main process, but can in a background. With a TEMPE, you can only get to that with ANT in a DF, but you can probably get the internal temp in a background process by just pulling it from Sensor.Info, but that's at most every 5 minutes. (edge devices are the only ones where Sensor.Info has the internal temp sensor info)
    If I recall, SensorHistory isn't available on the Edge Devices, but if it were, you could just grab the newest reading from that in the primary process.
  • Hi jdlien,
    I am looking for the same for an edge 1030. Let me know when you find a solution. I will do the same!
    Thank You
  • Here's a very simple sample (it works in the sim using simulated data). You need to have the "Background" and "Sensor in Background" permissions set.
    There's a background process that just returns the temperature:
    using Toybox.Background;
    using Toybox.System as Sys;
    // The Service Delegate is the main entry point for background processes
    // our onTemporalEvent() method will get run each time our periodic event
    // is triggered by the system.
    (:background)
    class TempBgServiceDelegate extends Toybox.System.ServiceDelegate {
    Sys.ServiceDelegate.initialize();
    function onTemporalEvent() {
    var si=Sensor.getInfo();
    Sys.println("returning="+si.temperature);
    Background.exit(si.temperature);
    And what your AppBase needs to look like. It enables temporal events (every 5 minutes here), etc. Value is put in a global named temp, and then in the view, that's just used.
    using Toybox.Application;
    var temp=0.0;
    class TempDFApp extends Application.AppBase {
    AppBase.initialize();
    // onStart() is called on application start up
    function onStart(state) {
    // onStop() is called when your application is exiting
    function onStop(state) {
    // Return the initial view of your application here
    function getInitialView() {
    if(Toybox.System has :ServiceDelegate) {
    Background.registerForTemporalEvent(new Time.Duration(5 * 60));
    return [ new TempDFView() ];
    function onBackgroundData(data) {
    temp=data;
    function getServiceDelegate(){
    return [new TempBgServiceDelegate()];
  • One thing to note here is after the DF is used once, the background process will run every 5 minutes, 24/7. This background process is really cheap resources wise for thos so I didn't include a trick where you can delete the temporal event when the DF stops running - in onStop() - you just need to know if that's running on behalf of the main process or the background. (onStart() is also run by both).
    I use a global called "isBackground" and default it to false, but change it to to true in the background process. Then in onStop(), if it's false, delete the temporal event.
  • Hi jim_m_58,
    Thank you. It was very helpfull.
    Regards
  • Backgrounding may seem a bit tricky, but it's really useful at times!
    I did a developer blog post with some of the basics a while back if you're looking for more info.
  • Hi Jim,
    Great work!
    I have 2 questions concerning compiling. Maybe you can help me:
    I have done some datafields and everything works fine. At this time they are only for own use. Maybe later on I will publish it on Connect IQ.
    Of course I have more PRG files (one for each datafield) that I put to the device.
    Now my question: How can I compile them all to get only one PRG file? With the export wizzard in Eclipse only one project can be selected.
    And the 2nd question: I have outsourced some global functions to a barrel. If I get only one PRG file, will the barrel be also only one time on the package, or will it be compiled with each single app?
    Best Regards
    Jo A. Kim
  • I have done some datafields and everything works fine. At this time they are only for own use. Maybe later on I will publish it on Connect IQ.
    If you have different DF's for a device, you want to "export" (create a .iq) for each one and upload them as separate apps to the store. The .iq is actually a zip file, and when you look, there's things like a folder for each part number, and the .prg for that devices.
    The barrel is a whole different thing, in that it's used to build a .prg, but isn't included when you do an "export". If you want to share a barrel, there actually isn't a common place or method to do that right now.
  • Regarding barrels: I was thinking (hoping) that a barrel can be compiled into a shared library, which multiple CIQ programs can access. But I cannot get this to work, so I am wondering if this is possible at all.
    I have a barrel, MyBarrel, and two data fields, MyField1 and MyField2. MyField1 and MyField2 use code from MyBarrel. I can compile MyField1 and MyField2 into executable .prg files (Eclipse menu Connect IQ > Build for device wizard), but I cannot use this menu to compile MyBarrel into a library, because MyBarrel does not show in the list of projects from which I have to select one to build. I can export MyBarrel (Eclipse menu Connect IQ > Export wizard), which creates a file called MyBarrel-n.n.n.barrel. Is this .barrel file a shared library that MyField1.prg and MyField2.prg can access? If so, where do I have to put it on my on my Garmin device? And how can I get MyField1.prg and MyField2.prg to access and use this library?
  • A barrel is a .zip of the project (sources files, etc). When you build MyField1 or MyField2, the barrel code gets compiled and is part of the resulting .prg. The barrel is for a library of code, but not a shared compiled unit (like like a dll would be on windows).
    You can see this if you open a barrel like you would a .zip file.
