Invalid Value/Failed invoking symbol when loading string on S60 watch (simulator OK)
This issue has been reported by various Approach S60 owners using my Crystal watch face:
https://apps.garmin.com/en-US/apps/9...7-17cfa0f0081b
The latest report was on an S60 running firmware 4.0.0, using a sideloaded version of the watch face, compiled using Eclipse 4.7.3a for Mac, with SDK 2.4.5.
I use a resource string for language detection, specifically, to detect Chinese languages , so that a different custom font can be loaded. Rez.Strings.DATE_FONT_OVERRIDE is an empty string for most languages, but "ZHS" for Chinese (Simplified), and "ZHT" for Chinese (Traditional).
This method works on all real watches, as far as I know, except for the S60. This method also works on S60 in the simulator.
A typical log for a crash is:
ERROR: Invalid Value
DETAILS: Failed invoking <symbol>
STORE_ID: 00000000000000000000000000000000
CALLSTACK:
/Users/vince/Documents/Projects/connect-iq/crystal-face/./source/DateLine.mc (initialize:48)
Rez (WatchFace:109)
/Users/vince/Documents/Projects/connect-iq/crystal-face/./source/CrystalView.mc (onLayout:83)
This points to the following line in the code:
var dateFontOverride = Ui.loadResource(Rez.Strings.DATE_FONT_OVERRIDE);
I have been able to deduce the following, some with the help of an S60 owner:
- Other strings load successfully, earlier on in the same function, using exactly the same pattern UI.loadResource(Rez.Strings.<string_id>), so there is not a general string loading problem.
- Renaming the string ID e.g. to "DateFont" does not solve the issue.
- Making the string non-empty e.g. "DEFAULT" does not solve the issue.
- Loading a different string at the same location in code (instead of the problematic one) works successfully.
- Removing the comment in the strings.xml file above the definition for the DATE_FONT_OVERRIDE string does not solve the issue. There are no unusual hidden characters in the base strings.xml file.
- S60 has some resource overrides (i.e. theres' a resources-approachs60 directory). This does not contain a strings.xml, but placing a copy of the "base" strings.xml in the appropriate sub-directory does not solve the issue.
- The problematic string was originally loaded before setLayout() was called. It's now called during the creation of a drawable within the layout, but that has not solved the issue.
The code is available on GitHub (link is to the specific hotfix branch with various fixes attempted and reverted):
https://github.com/warmsound/crystal...e/hotfix/%2320
The issue itself is tracked here:
https://github.com/warmsound/crystal-face/issues/20
Hopefully I'm not missing something obvious here! Any clues about how to proceed would be much appreciated.
Thanks,
Vince.
    I can confirm this issue is appearing on my watch. I've been working with Vince to troubleshoot. The watch face loads during watch face preview/selection with all items working as designed, but when attempting to load the watch face after selecting, it defaults back to the last Garmin preloaded face, and throws the error listed above.
    Hopefully someone can help!
  • Thanks for the report--we'll get this investigated!
    Just a quick update, I received firmware 4.10 this morning and the issue persists as explained.
    I've reached out to the device team to check on the progress here. I'll let you know when I know more.
    Thanks,
    - Coleman
    Thanks,
    - Coleman
    Hi there!
    Just curious if there has been any update on this issue? It's holding back what in my opinion is one of the only useful watch faces produced for the Garmin watches (especially the S60).
    Is there a way to request an increase in priority as there are a few issues with the S60, that don't appear on other watches that need to be fixed. It's unfortunate that this is one of Garmin's most expensive watches, and has many flaws compared to the vivoactive 3 or other lower cost watches.
    Thanks!
    DB88,
    I've reached out to our APAC team for an update. I'll let you know as soon as I know more.
    Thanks,
    -Coleman
